Acer Iconia One 10 B3-A30 Repair Camera Replacement
  1. Acer Iconia One 10 B3-A30 Repair Camera Replacement, Camera: step 1, image 1 of 2 Acer Iconia One 10 B3-A30 Repair Camera Replacement, Camera: step 1, image 2 of 2
    • Make sure the device is powered off.
    • Pry open media port cover at the top of the tablet.
    • Use the Phillips 00 screwdriver to remove the 1 mm screw.
  2. Acer Iconia One 10 B3-A30 Repair Camera Replacement: step 2, image 1 of 3 Acer Iconia One 10 B3-A30 Repair Camera Replacement: step 2, image 2 of 3 Acer Iconia One 10 B3-A30 Repair Camera Replacement: step 2, image 3 of 3
    • Using the metal spudger, carefully pry open the back cover.
  3. Acer Iconia One 10 B3-A30 Repair Camera Replacement: step 3, image 1 of 3 Acer Iconia One 10 B3-A30 Repair Camera Replacement: step 3, image 2 of 3 Acer Iconia One 10 B3-A30 Repair Camera Replacement: step 3, image 3 of 3
    • Using the plastic opening tool gently place the tip of it under the connection and pry up. It will pop out.
  4. Acer Iconia One 10 B3-A30 Repair Camera Replacement: step 4, image 1 of 2 Acer Iconia One 10 B3-A30 Repair Camera Replacement: step 4, image 2 of 2
    • Use the plastic opening tool to pry up the rear facing camera. Once removed the front facing camera will come out as well.
Austin Pickart
688 Reputation
5 Guides authored
USF Tampa, Team S1-G5, Nance Fall 2017 Member of USF Tampa, Team S1-G5, Nance Fall 2017
USFT-NANCE-F17S1G5
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 645
