Acer Iconia One 10 B3-A30 Repair Battery Replacement
  1. Acer Iconia One 10 B3-A30 Repair Battery Replacement, Battery: step 1, image 1 of 2 Acer Iconia One 10 B3-A30 Repair Battery Replacement, Battery: step 1, image 2 of 2
    • Make sure the device is powered off.
    • Open media port cover at the top of the tablet.
    • Use the Phillips #00 screwdriver to remove the 1 mm screw.
  2. Acer Iconia One 10 B3-A30 Repair Battery Replacement: step 2, image 1 of 3 Acer Iconia One 10 B3-A30 Repair Battery Replacement: step 2, image 2 of 3 Acer Iconia One 10 B3-A30 Repair Battery Replacement: step 2, image 3 of 3
    • Using the metal spudger, carefully pry open the back cover.
  3. Acer Iconia One 10 B3-A30 Repair Battery Replacement: step 3, image 1 of 1
    • Remove small section of grey tape.
  4. Acer Iconia One 10 B3-A30 Repair Battery Replacement: step 4, image 1 of 2 Acer Iconia One 10 B3-A30 Repair Battery Replacement: step 4, image 2 of 2
    • Unplug the connection cord from the motherboard.
  5. Acer Iconia One 10 B3-A30 Repair Battery Replacement: step 5, image 1 of 3 Acer Iconia One 10 B3-A30 Repair Battery Replacement: step 5, image 2 of 3 Acer Iconia One 10 B3-A30 Repair Battery Replacement: step 5, image 3 of 3
    • Try to remove the battery by pulling on the blue tabs.
    • If unsuccessful, use the black plastic spudger to gently break the glue bonds underneath and pull up to remove the battery.
    • Be very cautious not to puncture or bend the battery.
8 other people completed this guide.
Austin Pickart
688 Reputation
5 Guides authored
USF Tampa, Team S1-G5, Nance Fall 2017 Member of USF Tampa, Team S1-G5, Nance Fall 2017
USFT-NANCE-F17S1G5
4 Members
5 Guides authored
6 Comments
after replacing battery it will not turn on. There is a red light on when I plug in to charge. But screen is black. Nothing lights up not even a battery icon to show charging. Could the hard drive have been wiped in changing battery? Or that I waited too long to change battery as I used the tablet plugged in to the point the thing kept turning off even when plugged in
I have ACER iconia 10” tablet model B3-A40
howru100 - Reply
My problem ws iconia one a3_a40 is after start it says os android starting.and then message Power off turning down. Take time to start again.first touch lead to turning off message.is it android or acer bag?
alex_kolenko - Reply
First contac .taap on screen turns. Off device. service center technitian. Told me never to use android. Tauchscreen.
Means to use android without. Tapping screen keyboard or better to ask teenager in secondary school.they know better than educated ingeneeres. I am thinking to buy new gadget.
I have one of these and the battery is not taped down which is causing it to disconnect at times. Can anyone recommend a heat resistant tape to hold the battery in place?
Mark Cooper - Reply
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 64
All Time: 13,835
