Acer Iconia B1-711 V1-711 Logic Board Replacement
Video Overview
  1. Acer Iconia B1-711 V1-711 Logic Board Replacement, Back Cover: step 1, image 1 of 3 Acer Iconia B1-711 V1-711 Logic Board Replacement, Back Cover: step 1, image 2 of 3 Acer Iconia B1-711 V1-711 Logic Board Replacement, Back Cover: step 1, image 3 of 3
    • Switch-off the tablet.
    • Remove any SIM and/or Memory Card.
    • Start opening near to the Volume Up/Down buttons. It's more well to use a plastic opening tool to avoid damaging the cover.
    • When lifting the cover, be careful not to tear the Loudspeaker cable at the bottom right side.
    • Disconnect the Loudspeaker cable from the Logic board.
  2. Acer Iconia B1-711 V1-711 Logic Board Replacement: step 2, image 1 of 2 Acer Iconia B1-711 V1-711 Logic Board Replacement: step 2, image 2 of 2
    • Before doing anything, disconnect the battery.
  3. Acer Iconia B1-711 V1-711 Logic Board Replacement, Battery: step 3, image 1 of 2 Acer Iconia B1-711 V1-711 Logic Board Replacement, Battery: step 3, image 2 of 2
    • With a long plastic tool like a spudger, unstick the battery from the metal LCD shield.
    • Lithium Ion Battery Pack - 3.8V, 2710mAh
  4. Acer Iconia B1-711 V1-711 Logic Board Replacement, Audio Jack Connector: step 4, image 1 of 3 Acer Iconia B1-711 V1-711 Logic Board Replacement, Audio Jack Connector: step 4, image 2 of 3 Acer Iconia B1-711 V1-711 Logic Board Replacement, Audio Jack Connector: step 4, image 3 of 3
    • Unscrew 2x Philips screws
    • Disconnect and remove the Audio Jack Board flex cable.
    • Remove the board with the Audio Jack Connector.
  5. Acer Iconia B1-711 V1-711 Logic Board Replacement, Camera: step 5, image 1 of 3 Acer Iconia B1-711 V1-711 Logic Board Replacement, Camera: step 5, image 2 of 3 Acer Iconia B1-711 V1-711 Logic Board Replacement, Camera: step 5, image 3 of 3
    • Remove the Audio jack flex cable.
    • Remove the metal plate which is placed on the camera connector.
    • Disconnect the camera flex cable.
  6. Acer Iconia B1-711 V1-711 Logic Board Replacement: step 6, image 1 of 1
    • Remove the camera.
  7. Acer Iconia B1-711 V1-711 Logic Board Replacement, Microphone: step 7, image 1 of 3 Acer Iconia B1-711 V1-711 Logic Board Replacement, Microphone: step 7, image 2 of 3 Acer Iconia B1-711 V1-711 Logic Board Replacement, Microphone: step 7, image 3 of 3
    • Remove the tape from the microphone.
    • Disconnect the Microphone wires and remove the Microphone.
  8. Acer Iconia B1-711 V1-711 Logic Board Replacement, Logic Board: step 8, image 1 of 3 Acer Iconia B1-711 V1-711 Logic Board Replacement, Logic Board: step 8, image 2 of 3 Acer Iconia B1-711 V1-711 Logic Board Replacement, Logic Board: step 8, image 3 of 3
    • Remove the green rubber and disconnect the touch screen flex cable.
    • Disconnect the 4 coaxial antenna cables (Wi-Fi, GPS, 3G).
    • Carefully unstuck the metal folio from the LCD display flex cable.
    • Remove the 3x Phillips screws.
  9. Acer Iconia B1-711 V1-711 Logic Board Replacement: step 9, image 1 of 3 Acer Iconia B1-711 V1-711 Logic Board Replacement: step 9, image 2 of 3 Acer Iconia B1-711 V1-711 Logic Board Replacement: step 9, image 3 of 3
    • Lift the board from the side of the battery connector and turn it around the display connector on 360 degrees.
    • Be careful for the flex cable!
    • Disconnect the LCD display flex cable.
  10. Acer Iconia B1-711 V1-711 Logic Board Replacement: step 10, image 1 of 2 Acer Iconia B1-711 V1-711 Logic Board Replacement: step 10, image 2 of 2
    • This is the Logic board.
ZFix
191,590 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
321 Members
1,493 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 960
