Acer Chromebook Spin 11 R751TN-C5P3 Speakers Replacement
  1. Acer Chromebook Spin 11 R751TN-C5P3 Speakers Replacement, Battery: step 1, image 1 of 1
    • Flip the Chromebook face down.
    • Use a Phillips #0 screwdriver to remove the twelve 6 mm screws that secure the bottom cover.
  2. Acer Chromebook Spin 11 R751TN-C5P3 Speakers Replacement: step 2, image 1 of 2 Acer Chromebook Spin 11 R751TN-C5P3 Speakers Replacement: step 2, image 2 of 2
    • Insert an opening tool in the seam between the outer covers. Pushing down on the edge of the opening tool will cause the cover to lift up and reveal the internal components.
  3. Acer Chromebook Spin 11 R751TN-C5P3 Speakers Replacement: step 3, image 1 of 1
    • Grab the connecting cord between the battery and the motherboard and pull towards you to disconnect.
    • Remove any tape holding the battery cord down by pulling up on it.
  4. Acer Chromebook Spin 11 R751TN-C5P3 Speakers Replacement: step 4, image 1 of 1
    • The battery is no longer connected to the Chromebook allowing you to lift up and remove the battery.
  5. Acer Chromebook Spin 11 R751TN-C5P3 Speakers Replacement, Speakers: step 5, image 1 of 2 Acer Chromebook Spin 11 R751TN-C5P3 Speakers Replacement, Speakers: step 5, image 2 of 2
    • The speakers are connected a small amount of adhesive tape. They can be pulled out by gripping them and gently wiggling them up and out.
    • Unplug the cord connecting the speaker to the motherboard by gripping it on the sides and pulling.
  6. Acer Chromebook Spin 11 R751TN-C5P3 Speakers Replacement: step 6, image 1 of 1
    • Use a Phillips #0 screwdriver to remove the 3 mm screw that secures the trackpad. Lift the trackpad away to expose the cord connecting the two speakers.
  7. Acer Chromebook Spin 11 R751TN-C5P3 Speakers Replacement: step 7, image 1 of 1
    • Pull the cord out from the hooks to remove it.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 236
