Acer Chromebook CB5-571-C5XU Solid State Drive Replacement
  1. Acer Chromebook CB5-571-C5XU Solid State Drive Replacement, Bottom Case: step 1, image 1 of 2 Acer Chromebook CB5-571-C5XU Solid State Drive Replacement, Bottom Case: step 1, image 2 of 2
    • Remove the following eighteen screws using a Phillips #0 screwdriver.
    • Make sure the Chromebook is unplugged and shut down, so no files are lost and there is no risk of electrocution.
  2. Acer Chromebook CB5-571-C5XU Solid State Drive Replacement: step 2, image 1 of 2 Acer Chromebook CB5-571-C5XU Solid State Drive Replacement: step 2, image 2 of 2
    • Using the flat side of the spudger, pry open the bottom case of the laptop.
    • Working from the front to the back, where it connects to the screen, proved to be the easiest way of popping the case off.
  3. Acer Chromebook CB5-571-C5XU Solid State Drive Replacement, Solid State Drive: step 3, image 1 of 1
    • Using the Phillips #0 Screwdriver, unscrew the single screw holding the Solid State Drive in place.
  4. Acer Chromebook CB5-571-C5XU Solid State Drive Replacement: step 4, image 1 of 1
    • Gently lift the Solid State Drive upwards at an angle until it stops.
    • Be careful not to lift the Solid State Drive past where it stops, or you will risk breaking the hardware.
  5. Acer Chromebook CB5-571-C5XU Solid State Drive Replacement: step 5, image 1 of 1
    • Pull the Solid State Drive out from the socket in the direction of the angle at which it was resting.
    • The Solid State Drive should pull out with little effort. If it is resisting, do not pull harder, as this risks damage to the part.
2 other people completed this guide.
David Flint
273 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 12
All Time: 388
