Introduction
This guide will show you how to replace an unresponsive or otherwise broken touchpad. To do this, you must remove the laptop's backing and battery in order to access the touchpad. After removing the backing, another set of screws will need to be removed, so be sure to be careful in identifying which screws belong where when reassembling the device.
Position the laptop upside down with the hinges on the side furthest away from you.
Remove the eight 8mm screws with a phillips #1 screwdriver,
Remove the four 4.5mm screws with a phillips #1 screwdriver,
Locate and remove the two 6mm screws holding the battery in place with a Phillips #1 screwdriver.
Use a metal spudger to flip up the white ZIF connector that holds the ribbon cable in place.
Unplug the black ribbon cable from the track pad assembly.
