Acer Chromebook C731-C8VE Display Assembly Replacement
  1. Acer Chromebook C731-C8VE Display Assembly Replacement, Display Assembly: step 1, image 1 of 1
    • Place the Chromebook face down.
  2. Acer Chromebook C731-C8VE Display Assembly Replacement: step 2, image 1 of 2 Acer Chromebook C731-C8VE Display Assembly Replacement: step 2, image 2 of 2
    • Make sure to completely turn off the device before beginning this step.
    • Use a JIS #00 screwdriver to remove the 11 screws on the underside of the laptop.
    • The 2 mm screws marked orange have washers attached and must be placed in these specific areas.
    • These 2 mm screws do not have washers and will be located on the left and right of the device.
  3. Acer Chromebook C731-C8VE Display Assembly Replacement: step 3, image 1 of 3 Acer Chromebook C731-C8VE Display Assembly Replacement: step 3, image 2 of 3 Acer Chromebook C731-C8VE Display Assembly Replacement: step 3, image 3 of 3
    • Use the iFixit opening tool to remove the keyboard from the device by prying it loose from the base.
  4. Acer Chromebook C731-C8VE Display Assembly Replacement: step 4, image 1 of 3 Acer Chromebook C731-C8VE Display Assembly Replacement: step 4, image 2 of 3 Acer Chromebook C731-C8VE Display Assembly Replacement: step 4, image 3 of 3
    • Use the JIS #00 screwdriver to remove the four 1.5mm screws that connect the base of the laptop to the screen. There are two screws on each latch.
    • Carefully detach the cables that connect the screen to the motherboard. This includes a black display cable that connects to the mother board and two wires that connect to the Wi-Fi card.
  5. Acer Chromebook C731-C8VE Display Assembly Replacement: step 5, image 1 of 2 Acer Chromebook C731-C8VE Display Assembly Replacement: step 5, image 2 of 2
    • Do this step slowly to ensure that you do not damage the screen or the motherboard.
    • Remove the screen from the base of the device.
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 13
All Time: 275
