Acer Chromebook 15 C910-C453 Trackpad Replacement
  1. Acer Chromebook 15 C910-C453 Trackpad Replacement, Battery: step 1, image 1 of 2 Acer Chromebook 15 C910-C453 Trackpad Replacement, Battery: step 1, image 2 of 2
    • Turn the Chromebook onto its backside and unscrew the the following Phillips #1 screws:
    • Sixteen 5mm Phillips screws located around the border.
    • Two 5mm Phillips screws located in center.
  2. Acer Chromebook 15 C910-C453 Trackpad Replacement: step 2, image 1 of 1
    • Remove the back cover by carefully prying each side with an iFixit Opening Tool.
    • Set aside back cover.
  3. Acer Chromebook 15 C910-C453 Trackpad Replacement: step 3, image 1 of 2 Acer Chromebook 15 C910-C453 Trackpad Replacement: step 3, image 2 of 2
    • Using a spudger, carefully unplug the rainbow wires connected to the top of the battery.
  4. Acer Chromebook 15 C910-C453 Trackpad Replacement: step 4, image 1 of 2 Acer Chromebook 15 C910-C453 Trackpad Replacement: step 4, image 2 of 2
    • Unscrew the 4mm Phillips #1 screw located at the top right of battery.
  5. Acer Chromebook 15 C910-C453 Trackpad Replacement: step 5, image 1 of 1
    • Remove the battery.
  6. Acer Chromebook 15 C910-C453 Trackpad Replacement, Trackpad: step 6, image 1 of 2 Acer Chromebook 15 C910-C453 Trackpad Replacement, Trackpad: step 6, image 2 of 2
    • Unscrew the seven 6mm Phillips screws located around the trackpad.
  7. Acer Chromebook 15 C910-C453 Trackpad Replacement: step 7, image 1 of 1
    • Lift up the rectangular metal plate at the base.
  8. Acer Chromebook 15 C910-C453 Trackpad Replacement: step 8, image 1 of 2 Acer Chromebook 15 C910-C453 Trackpad Replacement: step 8, image 2 of 2
    • Flip the black bar where the white ribbon is connected to the trackpad upward to unlock it.
    • Gently pull the white ribbon away from the trackpad.
  9. Acer Chromebook 15 C910-C453 Trackpad Replacement: step 9, image 1 of 2 Acer Chromebook 15 C910-C453 Trackpad Replacement: step 9, image 2 of 2
    • Gently lift the trackpad up and pull towards you to remove the trackpad.
2 other people completed this guide.
Mia von Knorring
419 Reputation
1 Guide authored
Cal Poly, Team S15-G1, Banghart Spring 2017 Member of Cal Poly, Team S15-G1, Banghart Spring 2017
CPSU-BANGHART-S17S15G1
5 Members
11 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 412
