Acer Aspire TimelineX 4830T-6682 WiFi Card Replacement
  1. Acer Aspire TimelineX 4830T-6682 WiFi Card Replacement, Lower Back Panel: step 1, image 1 of 3 Acer Aspire TimelineX 4830T-6682 WiFi Card Replacement, Lower Back Panel: step 1, image 2 of 3 Acer Aspire TimelineX 4830T-6682 WiFi Card Replacement, Lower Back Panel: step 1, image 3 of 3
    • Remove the single screw with a Phillips #0 screwdriver.
    • Use a plastic opening tool on the upper part of the panel to remove it and access the RAM.
    • The other way to remove the panel is by sliding it away from the laptop. The difficulty of sliding it depends on the condition of your laptop.
  2. Acer Aspire TimelineX 4830T-6682 WiFi Card Replacement, WiFi Card: step 2, image 1 of 1
    • Remove the 3.6mm by 1.9mm WiFi Card screw with a Phillips #1 screwdriver
  3. Acer Aspire TimelineX 4830T-6682 WiFi Card Replacement: step 3, image 1 of 1
    • Remove the WiFi Card from the socket marked in picture
  4. Acer Aspire TimelineX 4830T-6682 WiFi Card Replacement: step 4, image 1 of 2 Acer Aspire TimelineX 4830T-6682 WiFi Card Replacement: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Remove the WiFi Card Antenna wire Connectors with tweezers
    • Remove the WiFi Card from the laptop
Jon Brunsell
592 Reputation
6 Guides authored
IUPUI, Team S1-G1, Beck Spring 2020 Member of IUPUI, Team S1-G1, Beck Spring 2020
IUPUI-BECK-S20S1G1
3 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 580
