Acer Aspire R5-571T-57Z0 Display Assembly Replacement
  1. Acer Aspire R5-571T-57Z0 Display Assembly Replacement, Battery: step 1, image 1 of 2 Acer Aspire R5-571T-57Z0 Display Assembly Replacement, Battery: step 1, image 2 of 2
    • Remove the three 4.0 mm screws from the battery using a Phillips #00 screwdriver.
    • Unplug the cable connected to the RAM.
    • Carefully remove the battery.
  2. Acer Aspire R5-571T-57Z0 Display Assembly Replacement, Display Assembly: step 2, image 1 of 2 Acer Aspire R5-571T-57Z0 Display Assembly Replacement, Display Assembly: step 2, image 2 of 2
    • Remove the six 4.0 mm screws from the hinges using a Phillips #00 screwdriver.
  3. Acer Aspire R5-571T-57Z0 Display Assembly Replacement: step 3, image 1 of 2 Acer Aspire R5-571T-57Z0 Display Assembly Replacement: step 3, image 2 of 2
    • Peel back the stickers from the display cable.
  4. Acer Aspire R5-571T-57Z0 Display Assembly Replacement: step 4, image 1 of 3 Acer Aspire R5-571T-57Z0 Display Assembly Replacement: step 4, image 2 of 3 Acer Aspire R5-571T-57Z0 Display Assembly Replacement: step 4, image 3 of 3
    • Hold back the film protecting the Wi-Fi card.
    • Disconnect the touch screen cable.
  5. Acer Aspire R5-571T-57Z0 Display Assembly Replacement: step 5, image 1 of 2 Acer Aspire R5-571T-57Z0 Display Assembly Replacement: step 5, image 2 of 2
    • Pull back the tape covering the connectors.
    • Detach the two connectors (one black wire, one white wire).
  6. Acer Aspire R5-571T-57Z0 Display Assembly Replacement: step 6, image 1 of 2 Acer Aspire R5-571T-57Z0 Display Assembly Replacement: step 6, image 2 of 2
    • Disconnect the touch control cable next to the black film.
  7. Acer Aspire R5-571T-57Z0 Display Assembly Replacement: step 7, image 1 of 2 Acer Aspire R5-571T-57Z0 Display Assembly Replacement: step 7, image 2 of 2
    • Flip over the laptop and pull back to remove the display assembly.
Kevin Chen
133 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 12
All Time: 232
