Acer Aspire ES1-111M-C7DE Network Card Replacement
  1. Acer Aspire ES1-111M-C7DE Network Card Replacement, Back Cover: step 1, image 1 of 2 Acer Aspire ES1-111M-C7DE Network Card Replacement, Back Cover: step 1, image 2 of 2
    • Unscrew the 13 6.2mm screws located on the bottom of the laptop using the JIS #0 screwdriver.
  2. Acer Aspire ES1-111M-C7DE Network Card Replacement: step 2, image 1 of 3 Acer Aspire ES1-111M-C7DE Network Card Replacement: step 2, image 2 of 3 Acer Aspire ES1-111M-C7DE Network Card Replacement: step 2, image 3 of 3
    • Using a plastic opening tool, gently pry the lower case off. Place aside.
  3. Acer Aspire ES1-111M-C7DE Network Card Replacement, Network Card: step 3, image 1 of 2 Acer Aspire ES1-111M-C7DE Network Card Replacement, Network Card: step 3, image 2 of 2
    • You will see a white rectangular piece next to the upper left-hand corner of the motherboard that is connected with a black cord and a white cord; this is the network card.
    • Unscrew the one 6.2mm screw in the upper left-hand corner of the network card.
  4. Acer Aspire ES1-111M-C7DE Network Card Replacement: step 4, image 1 of 3 Acer Aspire ES1-111M-C7DE Network Card Replacement: step 4, image 2 of 3 Acer Aspire ES1-111M-C7DE Network Card Replacement: step 4, image 3 of 3
    • Remove the black and the white cords from the network card.
    • Slide the card out of the motherboard and replace it with the new one.
Payton Stewart
101 Reputation
1 Guide authored
USF Tampa, Team S3-G1, Cannon Fall 2017 Member of USF Tampa, Team S3-G1, Cannon Fall 2017
USFT-CANNON-F17S3G1
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 268
