Acer Aspire ES1-111M-C7DE Battery Replacement
  1. Acer Aspire ES1-111M-C7DE Battery Replacement, Back Cover: step 1, image 1 of 2 Acer Aspire ES1-111M-C7DE Battery Replacement, Back Cover: step 1, image 2 of 2
    • Unscrew the 13 6.2mm screws located on the bottom of the laptop using the JIS #0 screwdriver.
  2. Acer Aspire ES1-111M-C7DE Battery Replacement: step 2, image 1 of 3 Acer Aspire ES1-111M-C7DE Battery Replacement: step 2, image 2 of 3 Acer Aspire ES1-111M-C7DE Battery Replacement: step 2, image 3 of 3
    • Using a plastic opening tool, gently pry the lower case off. Place aside.
  3. Acer Aspire ES1-111M-C7DE Battery Replacement, Battery: step 3, image 1 of 2 Acer Aspire ES1-111M-C7DE Battery Replacement, Battery: step 3, image 2 of 2
    • Locate the small black button surrounded by a white circle near the battery on the motherboard.
    • Press and hold the button for five seconds.
  4. Acer Aspire ES1-111M-C7DE Battery Replacement: step 4, image 1 of 3 Acer Aspire ES1-111M-C7DE Battery Replacement: step 4, image 2 of 3 Acer Aspire ES1-111M-C7DE Battery Replacement: step 4, image 3 of 3
    • Using your fingers or the small plastic opening tools, disconnect the battery connection from the motherboard by pinching and pulling back on both sides of the connector.
  5. Acer Aspire ES1-111M-C7DE Battery Replacement: step 5, image 1 of 3 Acer Aspire ES1-111M-C7DE Battery Replacement: step 5, image 2 of 3 Acer Aspire ES1-111M-C7DE Battery Replacement: step 5, image 3 of 3
    • Locate the two 6.2mm black screws holding the battery in place and unscrew them.
    • Gently lift and remove the battery.
Reid Becker
103 Reputation
1 Guide authored
USF Tampa, Team S3-G1, Cannon Fall 2017 Member of USF Tampa, Team S3-G1, Cannon Fall 2017
USFT-CANNON-F17S3G1
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 14
All Time: 1,728
