Acer Aspire E1-571 - Heat Sink Cleaning, Thermal Paste Replacing
Video Overview
  1. Acer Aspire E1-571 - Heat Sink Cleaning, Thermal Paste Replacing, Heat Sink Cleaning, Thermal Paste Replacing: step 1, image 1 of 3 Acer Aspire E1-571 - Heat Sink Cleaning, Thermal Paste Replacing, Heat Sink Cleaning, Thermal Paste Replacing: step 1, image 2 of 3 Acer Aspire E1-571 - Heat Sink Cleaning, Thermal Paste Replacing, Heat Sink Cleaning, Thermal Paste Replacing: step 1, image 3 of 3
    • Switch-off the laptop.
    • Remove the battery and the DVD drive.
  2. Acer Aspire E1-571 - Heat Sink Cleaning, Thermal Paste Replacing: step 2, image 1 of 3 Acer Aspire E1-571 - Heat Sink Cleaning, Thermal Paste Replacing: step 2, image 2 of 3 Acer Aspire E1-571 - Heat Sink Cleaning, Thermal Paste Replacing: step 2, image 3 of 3
    • Unscrew 2x screws M 2.5x8.0
    • With a plastic tool remove the Memory RAM / Hard Drive / Wifi Cover Door
  3. Acer Aspire E1-571 - Heat Sink Cleaning, Thermal Paste Replacing: step 3, image 1 of 3 Acer Aspire E1-571 - Heat Sink Cleaning, Thermal Paste Replacing: step 3, image 2 of 3 Acer Aspire E1-571 - Heat Sink Cleaning, Thermal Paste Replacing: step 3, image 3 of 3
  4. Acer Aspire E1-571 - Heat Sink Cleaning, Thermal Paste Replacing: step 4, image 1 of 3 Acer Aspire E1-571 - Heat Sink Cleaning, Thermal Paste Replacing: step 4, image 2 of 3 Acer Aspire E1-571 - Heat Sink Cleaning, Thermal Paste Replacing: step 4, image 3 of 3
    • The Keyboard is held by 6x locking clips at up and 2x at both sides.
    • Use plastic tool to unlock 6x upper clips.
    • Disconnect the keyboard flex cable and you are ready to install the new keyboard.
    • More detailed information for this step you can found in this manual: Acer Aspire E1-571 - Keyboard Replacement
  5. Acer Aspire E1-571 - Heat Sink Cleaning, Thermal Paste Replacing: step 5, image 1 of 3 Acer Aspire E1-571 - Heat Sink Cleaning, Thermal Paste Replacing: step 5, image 2 of 3 Acer Aspire E1-571 - Heat Sink Cleaning, Thermal Paste Replacing: step 5, image 3 of 3
    • Now is time for screws :)
    • 16x M3.0x8.0
    • 2x M2.5x5.0
    • 3x M2.0x3.0
  6. Acer Aspire E1-571 - Heat Sink Cleaning, Thermal Paste Replacing: step 6, image 1 of 3 Acer Aspire E1-571 - Heat Sink Cleaning, Thermal Paste Replacing: step 6, image 2 of 3 Acer Aspire E1-571 - Heat Sink Cleaning, Thermal Paste Replacing: step 6, image 3 of 3
    • Power switch cable connector
    • Mouse cable connector
    • Use plastic tool to separate the upper case.
  7. Acer Aspire E1-571 - Heat Sink Cleaning, Thermal Paste Replacing: step 7, image 1 of 3 Acer Aspire E1-571 - Heat Sink Cleaning, Thermal Paste Replacing: step 7, image 2 of 3 Acer Aspire E1-571 - Heat Sink Cleaning, Thermal Paste Replacing: step 7, image 3 of 3
    • Remove the 2x screws and disconnect 5x flex cable connectors:
    • 2x Loudspeakers cable connectors
    • LCD Display cable connector
    • Microphone cable connector
    • USB board flex cable connector
    • Don't forget to remove the Card Reader Blanking Plate.
    • To take out the Motherboard, pick-up it first from the right side (near to the DVD drive connector).
  8. Acer Aspire E1-571 - Heat Sink Cleaning, Thermal Paste Replacing: step 8, image 1 of 2 Acer Aspire E1-571 - Heat Sink Cleaning, Thermal Paste Replacing: step 8, image 2 of 2
    • Disconnect the Power /Charging cable connector from the back side of the Motherboard.
  9. Acer Aspire E1-571 - Heat Sink Cleaning, Thermal Paste Replacing: step 9, image 1 of 3 Acer Aspire E1-571 - Heat Sink Cleaning, Thermal Paste Replacing: step 9, image 2 of 3 Acer Aspire E1-571 - Heat Sink Cleaning, Thermal Paste Replacing: step 9, image 3 of 3
    • 3x screws hold the fan to the Motherboard.
    • Another 4x screws and you can open and clean the fan from inside.
  10. Acer Aspire E1-571 - Heat Sink Cleaning, Thermal Paste Replacing: step 10, image 1 of 2 Acer Aspire E1-571 - Heat Sink Cleaning, Thermal Paste Replacing: step 10, image 2 of 2
    • Clean the radiator by using soft brush.
  11. Acer Aspire E1-571 - Heat Sink Cleaning, Thermal Paste Replacing: step 11, image 1 of 3 Acer Aspire E1-571 - Heat Sink Cleaning, Thermal Paste Replacing: step 11, image 2 of 3 Acer Aspire E1-571 - Heat Sink Cleaning, Thermal Paste Replacing: step 11, image 3 of 3
    • Remove the heat sink system.
    • Careful remove the old thermal patse from the Processor and from the Head-sync system.
  12. Acer Aspire E1-571 - Heat Sink Cleaning, Thermal Paste Replacing: step 12, image 1 of 3 Acer Aspire E1-571 - Heat Sink Cleaning, Thermal Paste Replacing: step 12, image 2 of 3 Acer Aspire E1-571 - Heat Sink Cleaning, Thermal Paste Replacing: step 12, image 3 of 3
    • Put a new thermal paste. Cover the entire surface of the CPU crystal.
    • Install the Heat-sync system and screw the screws at a few steps.
  13. Acer Aspire E1-571 - Heat Sink Cleaning, Thermal Paste Replacing: step 13, image 1 of 1
    • Assemble the laptop and after switch-on it check is the fan working.
7 other people completed this guide.
ZFix
191,674 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
321 Members
1,512 Guides authored
4 Comments
Sir acer e1 571 me cpu kon sa hota hy matlb uska no kya hota hy core i5 kaa hmko confrm karna hy kyu ki maine apna lapie dukan pe diya tha aur mujhe dr hy ki wo nera cpu to nhi change kardiya
chaudharypiyush496 - Reply
This video was a lifesaver. It helped me take apart My E1 in order to replace the thermalpaste and cleanup he cooling. Big Thanks!
Chris Smith - Reply
Thank You, this worked great on an Acer V3-571, totally removed cooling/fan issues, Thank You.
Shane Archer - Reply
My laptop wont turn on after doing this, please help me!
Sean Matthew - Reply
Past 24 Hours: 6
Past 7 Days: 27
Past 30 Days: 73
All Time: 18,578
