Acer Aspire E1-510P-4637 RAM Replacement
  1. Acer Aspire E1-510P-4637 RAM Replacement, Battery: step 1, image 1 of 1
    • To release the battery, depress the battery release with a nylon spudger. Hold the latch down and slide it over.
  2. Acer Aspire E1-510P-4637 RAM Replacement: step 2, image 1 of 1
    • Firmly grab hold of the battery and slide it out of the laptop.
  3. Acer Aspire E1-510P-4637 RAM Replacement, RAM: step 3, image 1 of 1
    • Remove the M2.5x8 screw with a PH1 screwdriver.
  4. Acer Aspire E1-510P-4637 RAM Replacement: step 4, image 1 of 1
    • Use the plastic opening tool to pop up off the back cover.
  5. Acer Aspire E1-510P-4637 RAM Replacement: step 5, image 1 of 3 Acer Aspire E1-510P-4637 RAM Replacement: step 5, image 2 of 3 Acer Aspire E1-510P-4637 RAM Replacement: step 5, image 3 of 3
    • Use your fingers to pinch the retaining latch. This will free the RAM.
  6. Acer Aspire E1-510P-4637 RAM Replacement: step 6, image 1 of 3 Acer Aspire E1-510P-4637 RAM Replacement: step 6, image 2 of 3 Acer Aspire E1-510P-4637 RAM Replacement: step 6, image 3 of 3
    • Rotate the RAM sticks up and slide the RAM out.
Caleb lindsay
778 Reputation
6 Guides authored
Cal Poly, Team 34-15, Maness Spring 2016 Member of Cal Poly, Team 34-15, Maness Spring 2016
CPSU-MANESS-S16S34G15
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 6
All Time: 388
