Acer Aspire E1-510P-4637 Keyboard Replacement
  1. Acer Aspire E1-510P-4637 Keyboard Replacement, Battery: step 1, image 1 of 1
    • To release the battery, depress the battery release with a nylon spudger. Hold the latch down and slide it over.
  2. Acer Aspire E1-510P-4637 Keyboard Replacement: step 2, image 1 of 1
    • Firmly grab hold of the battery and slide it out of the laptop.
  3. Acer Aspire E1-510P-4637 Keyboard Replacement, Hard Drive: step 3, image 1 of 1
    • Remove the M2.5x8 screw with a PH1 screwdriver.
  4. Acer Aspire E1-510P-4637 Keyboard Replacement: step 4, image 1 of 1
    • Use the plastic opening tool to pop off the small back cover.
  5. Acer Aspire E1-510P-4637 Keyboard Replacement: step 5, image 1 of 1
    • Use a PH0 Phillips screwdriver to remove the screw securing the hard drive.
  6. Acer Aspire E1-510P-4637 Keyboard Replacement: step 6, image 1 of 2 Acer Aspire E1-510P-4637 Keyboard Replacement: step 6, image 2 of 2
    • Use a nylon spudger to slightly pry up the hard drive near the screw holes.
  7. Acer Aspire E1-510P-4637 Keyboard Replacement: step 7, image 1 of 3 Acer Aspire E1-510P-4637 Keyboard Replacement: step 7, image 2 of 3 Acer Aspire E1-510P-4637 Keyboard Replacement: step 7, image 3 of 3
    • Grab hold of the plastic tab and pull the hard drive away from the connectors. This will release the hard drive.
    • The hard drive connector is fragile. Handle with care.
  8. Acer Aspire E1-510P-4637 Keyboard Replacement, Keyboard: step 8, image 1 of 1
    • Remove the fourteen M2.5x8 screws highlighted in the picture with a PH0 Phillips screwdriver.
  9. Acer Aspire E1-510P-4637 Keyboard Replacement: step 9, image 1 of 1
    • Slide out the disk drive tray.
  10. Acer Aspire E1-510P-4637 Keyboard Replacement: step 10, image 1 of 1
    • Use the plastic opening tool to gently pry open the laptop.
  11. Acer Aspire E1-510P-4637 Keyboard Replacement: step 11, image 1 of 3 Acer Aspire E1-510P-4637 Keyboard Replacement: step 11, image 2 of 3 Acer Aspire E1-510P-4637 Keyboard Replacement: step 11, image 3 of 3
    • Rotate the back cover up a little to reveal the cables connected to the motherboard.
    • Unplug the cables by sliding them out of their receptacle.
    • The connectors are very small and fragile. Handle with care.
  12. Acer Aspire E1-510P-4637 Keyboard Replacement: step 12, image 1 of 1
    • Remove the four center panel M1.6x3 screws with a PH0 Phillips screwdriver.
    • Remove the two M2x3 screws with a PH0 Phillips screwdriver.
  13. Acer Aspire E1-510P-4637 Keyboard Replacement: step 13, image 1 of 3 Acer Aspire E1-510P-4637 Keyboard Replacement: step 13, image 2 of 3 Acer Aspire E1-510P-4637 Keyboard Replacement: step 13, image 3 of 3
    • Use the plastic opening tool to slide the metal part out to release it from the retaining tabs.
  14. Acer Aspire E1-510P-4637 Keyboard Replacement: step 14, image 1 of 2 Acer Aspire E1-510P-4637 Keyboard Replacement: step 14, image 2 of 2
    • Peel off the foil adhesive stuck to the keyboard.
  15. Acer Aspire E1-510P-4637 Keyboard Replacement: step 15, image 1 of 1
    • Remove the keyboard.
2 other people completed this guide.
Caleb lindsay
778 Reputation
6 Guides authored
Cal Poly, Team 34-15, Maness Spring 2016 Member of Cal Poly, Team 34-15, Maness Spring 2016
CPSU-MANESS-S16S34G15
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 14
All Time: 1,176
