Acer Aspire A515-51G Lower Case Replacement
  1. Acer Aspire A515-51G Lower Case Replacement, Unfasten the HDD hatch: step 1, image 1 of 2 Acer Aspire A515-51G Lower Case Replacement, Unfasten the HDD hatch: step 1, image 2 of 2
    • Use a Phillips screwdriver to remove the screw securing the HDD hatch on the bottom left of the lower case.
  2. Acer Aspire A515-51G Lower Case Replacement, Remove the HDD hatch: step 2, image 1 of 3 Acer Aspire A515-51G Lower Case Replacement, Remove the HDD hatch: step 2, image 2 of 3 Acer Aspire A515-51G Lower Case Replacement, Remove the HDD hatch: step 2, image 3 of 3
    • Insert the flat end of a spudger under the cutout on the top right corner of the HDD hatch and pry it up.
    • Remove the HDD hatch.
  3. Acer Aspire A515-51G Lower Case Replacement, Unfasten the HDD assembly: step 3, image 1 of 2 Acer Aspire A515-51G Lower Case Replacement, Unfasten the HDD assembly: step 3, image 2 of 2
    • Your HDD assembly may be secured to the lower case with screws. If it's not, skip this step.
    • Use a Phillips screwdriver to remove the four screws securing the HDD assembly.
  4. Acer Aspire A515-51G Lower Case Replacement: step 4, image 1 of 3 Acer Aspire A515-51G Lower Case Replacement: step 4, image 2 of 3 Acer Aspire A515-51G Lower Case Replacement: step 4, image 3 of 3
    • Firmly grip the HDD assembly and HDD cable connector head.
    • Pull the HDD cable connector out of its socket.
    • Remove the HDD assembly.
  5. Acer Aspire A515-51G Lower Case Replacement, Unfasten the lower case: step 5, image 1 of 2 Acer Aspire A515-51G Lower Case Replacement, Unfasten the lower case: step 5, image 2 of 2
    • Use a Phillips screwdriver to remove the eighteen 6.6 mm screws securing the case.
  6. Acer Aspire A515-51G Lower Case Replacement, Insert an opening pick: step 6, image 1 of 2 Acer Aspire A515-51G Lower Case Replacement, Insert an opening pick: step 6, image 2 of 2
    • Insert an opening pick between the lower case and the chassis on the front right edge.
  7. Acer Aspire A515-51G Lower Case Replacement, Release the case's front clips: step 7, image 1 of 3 Acer Aspire A515-51G Lower Case Replacement, Release the case's front clips: step 7, image 2 of 3 Acer Aspire A515-51G Lower Case Replacement, Release the case's front clips: step 7, image 3 of 3
    • Slide the pick along the front edge to release the clips securing the lower case.
  8. Acer Aspire A515-51G Lower Case Replacement, Release the remaining clips: step 8, image 1 of 2 Acer Aspire A515-51G Lower Case Replacement, Release the remaining clips: step 8, image 2 of 2
    • Continue sliding the opening pick along the perimeter of the lower case to release the remaining clips.
  9. Acer Aspire A515-51G Lower Case Replacement: step 9, image 1 of 3 Acer Aspire A515-51G Lower Case Replacement: step 9, image 2 of 3 Acer Aspire A515-51G Lower Case Replacement: step 9, image 3 of 3
    • Lift the lower case from the chassis and remove it.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
Take your e-waste to an R2 or e-stewards certified recycler.
Repair didn't go as planned? Try some basic troubleshooting, or ask our Acer Aspire answers community for help.
Spencer Day
58,680 Reputation
430 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,535 Guides authored
0 Comments
Past 24 Hours: 6
Past 7 Days: 23
Past 30 Days: 82
All Time: 1,236
