Acer Aspire 5534-1096 Wi-Fi Chip Replacement
  1. Acer Aspire 5534-1096 Wi-Fi Chip Replacement, Wi-Fi Chip: step 1, image 1 of 1
    • Unscrew the two 4.8mm Phillips #00 screws on the bottom panel.
  2. Acer Aspire 5534-1096 Wi-Fi Chip Replacement: step 2, image 1 of 1
    • Use the spudger to gently pry open the access cover.
  3. Acer Aspire 5534-1096 Wi-Fi Chip Replacement: step 3, image 1 of 2 Acer Aspire 5534-1096 Wi-Fi Chip Replacement: step 3, image 2 of 2
    Tool used on this step:
    Buy
    • Remove the Phillips #00 screw from the upper right corner of the Wi-Fi chip.
    • Using the tweezers, disconnect the black and white wires.
  4. Acer Aspire 5534-1096 Wi-Fi Chip Replacement: step 4, image 1 of 3 Acer Aspire 5534-1096 Wi-Fi Chip Replacement: step 4, image 2 of 3 Acer Aspire 5534-1096 Wi-Fi Chip Replacement: step 4, image 3 of 3
    • Use your fingers to remove the Wi-Fi chip from the laptop.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 165
