Aarp RealPad MA7BX2 Speakers Replacement
  1. Aarp RealPad MA7BX2 Speakers Replacement, Speakers: step 1, image 1 of 1
    • Loosen the back cover using the suction cup.
    • Pull up on all four corners of the back with the suction cup.
  2. Aarp RealPad MA7BX2 Speakers Replacement: step 2, image 1 of 1
    • Gently place the small opening tool in the crevice created by loosening the back.
    • Slide the opening tool around the edges of the device.
    • Wedge it open using the plastic opening tool.
  3. Aarp RealPad MA7BX2 Speakers Replacement: step 3, image 1 of 1
    • Gently pull off the black tape.
  4. Aarp RealPad MA7BX2 Speakers Replacement: step 4, image 1 of 1
    Tool used on this step:
    Buy
    • Remove the wires with the tweezers by pulling them upward.
  5. Aarp RealPad MA7BX2 Speakers Replacement: step 5, image 1 of 2 Aarp RealPad MA7BX2 Speakers Replacement: step 5, image 2 of 2
    • Pull the speakers upward with you hand.
To reassemble your device you will need to solder the wires back in position and then follow the other steps in reverse order.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 192
