ASUS ZENFONE 3 Zoom Fingerprint Scanner Replacement
  1. ASUS ZENFONE 3 Zoom Fingerprint Scanner Replacement, Battery: step 1, image 1 of 2 ASUS ZENFONE 3 Zoom Fingerprint Scanner Replacement, Battery: step 1, image 2 of 2
    Tool used on this step:
    Buy
    • Using a pair of tweezers, pull put the SIM card tray and set it to the side.
  2. ASUS ZENFONE 3 Zoom Fingerprint Scanner Replacement: step 2, image 1 of 1
    • Remove the two 2 mm screws using a Torx T2 screwdriver.
  3. ASUS ZENFONE 3 Zoom Fingerprint Scanner Replacement: step 3, image 1 of 2 ASUS ZENFONE 3 Zoom Fingerprint Scanner Replacement: step 3, image 2 of 2
    • Insert a prying tool between the screen and the metal backing of the phone at the bottom to remove backing from phone.
    • There will be a thin film connecting the two pieces. You do not need to remove this. Just fold the two pieces apart with the inside facing up.
  4. ASUS ZENFONE 3 Zoom Fingerprint Scanner Replacement: step 4, image 1 of 1
    • Remove the two 3 mm screws, using the Phillips #00 screwdriver, on the silver band at the top of the battery and remove the band.
  5. ASUS ZENFONE 3 Zoom Fingerprint Scanner Replacement: step 5, image 1 of 1
    • Peel back the silver tape.
  6. ASUS ZENFONE 3 Zoom Fingerprint Scanner Replacement: step 6, image 1 of 1
    • Disconnect the battery connections.
  7. ASUS ZENFONE 3 Zoom Fingerprint Scanner Replacement: step 7, image 1 of 1
    • Pry and remove the battery.
    • The underside of the battery is adhesive so make sure to pry the battery off gently.
  8. ASUS ZENFONE 3 Zoom Fingerprint Scanner Replacement, Fingerprint Scanner: step 8, image 1 of 1
    • Unplug the wire connecting the two large pieces of the device. Next, seperate the two halves of the phone.
  9. ASUS ZENFONE 3 Zoom Fingerprint Scanner Replacement: step 9, image 1 of 3 ASUS ZENFONE 3 Zoom Fingerprint Scanner Replacement: step 9, image 2 of 3 ASUS ZENFONE 3 Zoom Fingerprint Scanner Replacement: step 9, image 3 of 3
    • Using the plastic opening tool, pry the fingerprint scanner out.
0 Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 13
All Time: 677
