Introduction
Use this guide to replace the lower case on your ASUS TUF Gaming F15 FX506HEB-DB74.
Before you perform this repair, be sure to completely power off and unplug your laptop. Make sure the laptop is not in standby, sleep, or hibernation mode.
Remove the 11 Phillips screws securing the lower case:
Seven 11.6 mm screws
Two 14.6 mm screws
Two 6.1 mm screws
Insert an opening pick between the lower case and the chassis on the front right edge.
Slide the pick along the right edge to release the clips securing the lower case.
Continue sliding the opening pick along the perimeter of the lower case to release the remaining clips.
Take your e-waste to an R2 or e-stewards certified recycler.
Repair didn't go as planned? Try some basic troubleshooting, or ask our ASUS TUF answers community for help.
2 Comments
What's the diameter of the screw? I've been missing a screw and I want to buy online but I don't know what the size. The screw of the lowercase btw. Thanks!
Hi! All the back cover screw heads are approximately 4.4 mm in diameter. Hope that helps!
