ASUS ROG Strix GL503VD-DB71 Fan Replacement
  1. ASUS ROG Strix GL503VD-DB71 Fan Replacement, Fan: step 1, image 1 of 3 ASUS ROG Strix GL503VD-DB71 Fan Replacement, Fan: step 1, image 2 of 3 ASUS ROG Strix GL503VD-DB71 Fan Replacement, Fan: step 1, image 3 of 3
    • Flip the laptop over so that the bottom is facing up.
    • Remove the ten screws around the edges and in the center of the back case with a Phillips #1 screwdriver.
  2. ASUS ROG Strix GL503VD-DB71 Fan Replacement: step 2, image 1 of 3 ASUS ROG Strix GL503VD-DB71 Fan Replacement: step 2, image 2 of 3 ASUS ROG Strix GL503VD-DB71 Fan Replacement: step 2, image 3 of 3
    • Pry up the triangular service cover with a plastic opening tool.
    • Remove the single Phillips #1 screw beneath the cover.
    • Pry up the remainder of the back cover with a plastic opening tool and remove the back cover.
  3. ASUS ROG Strix GL503VD-DB71 Fan Replacement: step 3, image 1 of 3 ASUS ROG Strix GL503VD-DB71 Fan Replacement: step 3, image 2 of 3 ASUS ROG Strix GL503VD-DB71 Fan Replacement: step 3, image 3 of 3
    • Remove the four screws from the fans with a Phillips #1 screwdriver.
    • Unplug each of the fan connectors from the motherboard.
    • Remove each fan by lifting it from the case.
2 Comments
Hi! I have a GL503VD-EB72 and my fans look ever so slightly different. Trying to replace one right now but I’m seeing a lot of variety in what’s available on eBay and amazon…How can I tell if my fans are 5V or 12V?
Kirsten M - Reply
WTF i can find a 12 V for my GL503V
mrparisalexandre - Reply
Past 24 Hours: 4
Past 7 Days: 11
Past 30 Days: 55
All Time: 4,600
