ASUS ROG Strix GL503VD-DB71 Display Replacement
  1. ASUS ROG Strix GL503VD-DB71 Display Replacement, Display: step 1, image 1 of 3 ASUS ROG Strix GL503VD-DB71 Display Replacement, Display: step 1, image 2 of 3 ASUS ROG Strix GL503VD-DB71 Display Replacement, Display: step 1, image 3 of 3
    • Open the laptop where the screen is now showing
    • Find the two stickers on the bottom of the display and remove them
    • Use the Phillips #1 screwdriver to take out the two screws at the bottom of the display.
  2. ASUS ROG Strix GL503VD-DB71 Display Replacement: step 2, image 1 of 3 ASUS ROG Strix GL503VD-DB71 Display Replacement: step 2, image 2 of 3 ASUS ROG Strix GL503VD-DB71 Display Replacement: step 2, image 3 of 3
    • Use the plastic opening tool to remove the plastic bezel around the screen.
    • Pry the remainder of the cover off of the hinges at the bottom of the sides of the display.
  3. ASUS ROG Strix GL503VD-DB71 Display Replacement: step 3, image 1 of 3 ASUS ROG Strix GL503VD-DB71 Display Replacement: step 3, image 2 of 3 ASUS ROG Strix GL503VD-DB71 Display Replacement: step 3, image 3 of 3
    • Using a Phillips #1 screwdriver, remove the four screws at the top and bottom of the display.
    • Unplug the display from the rest of the laptop at the back bottom of the display.
    • Remove the display.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 26
All Time: 1,211
