ASUS Portable AiO PT2001 Battery Replacement
  1. ASUS Portable AiO PT2001 Battery Replacement, Back Panel: step 1, image 1 of 3 ASUS Portable AiO PT2001 Battery Replacement, Back Panel: step 1, image 2 of 3 ASUS Portable AiO PT2001 Battery Replacement, Back Panel: step 1, image 3 of 3
    • Remove the grey scuff guard at the bottom of the PC by pressing down on it, and pulling it away.
    • Lift the hinge and remove the grey rubber tabs on either side of the PC’s model information.
    • Remove the two 7.62mm Phillips #1 screws beneath the rubber tabs under the hinge and the four 7.62mm Phillips #1 screws where the scuff guard was removed.
    • Remove the two 4.74mm Phillips #1 screws under the hinge (near the hinge joints) and a 4.74mm Phillips #1 screw under the handle.
  2. ASUS Portable AiO PT2001 Battery Replacement: step 2, image 1 of 3 ASUS Portable AiO PT2001 Battery Replacement: step 2, image 2 of 3 ASUS Portable AiO PT2001 Battery Replacement: step 2, image 3 of 3
    • Use 1-2 plastic opening tools or nylon spudgers to firmly pry open the back panel.
    • We recommend that you start prying the panel where the scuff guard was removed.
    • Prying the back panel will cause loud popping noises. This is just the sound of the clips that hold the back panel to the PC popping off.
    • Using excess force while prying can break the clips that hold the back panel and can damage the ports on the side of the PC.
  3. ASUS Portable AiO PT2001 Battery Replacement: step 3, image 1 of 3 ASUS Portable AiO PT2001 Battery Replacement: step 3, image 2 of 3 ASUS Portable AiO PT2001 Battery Replacement: step 3, image 3 of 3
    • Disconnect the three cables connecting the back panel ports to the motherboard.
    • Flip up the locking latch holding the two ribbon cables with a plastic opening tool and pull the cables out.
    • Gently wiggle the third connector out of its socket.
  4. ASUS Portable AiO PT2001 Battery Replacement, Battery: step 4, image 1 of 1
    • Remove the eight 3.5 mm Phillips screws that secure the battery.
  5. ASUS Portable AiO PT2001 Battery Replacement: step 5, image 1 of 2 ASUS Portable AiO PT2001 Battery Replacement: step 5, image 2 of 2
    • Disconnect the wires by pulling on the tab. Disconnecting these wires will clear the way for removing the battery.
  6. ASUS Portable AiO PT2001 Battery Replacement: step 6, image 1 of 1
    • Unplug the battery's connector from the motherboard.
  7. ASUS Portable AiO PT2001 Battery Replacement: step 7, image 1 of 1
    • Pull the battery out. Be careful not to break the cables on top.
2 other people completed this guide.
Runjia Chen
295 Reputation
2 Guides authored
Cal Poly, Team S17-G5, Livingston Spring 2018 Member of Cal Poly, Team S17-G5, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G5
4 Members
16 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 27
All Time: 2,304
