ASUS PadFone X Speaker Replacement
  1. ASUS PadFone X Speaker Replacement, Speaker: step 1, image 1 of 2 ASUS PadFone X Speaker Replacement, Speaker: step 1, image 2 of 2
    • Pry off the back cover with the blue plastic opening tool. This may require a bit of force.
  2. ASUS PadFone X Speaker Replacement: step 2, image 1 of 2 ASUS PadFone X Speaker Replacement: step 2, image 2 of 2
    • Remove the thirteen 3.6mm screws using the T5 Torx Screwdriver.
  3. ASUS PadFone X Speaker Replacement: step 3, image 1 of 1
    • Once the screws are removed, the mid-frame can be lifted off of the phone. The speaker is on the mid-frame.
  4. ASUS PadFone X Speaker Replacement: step 4, image 1 of 2 ASUS PadFone X Speaker Replacement: step 4, image 2 of 2
    • Use the plastic opening tool to pry out the speaker. It should come out fairly easily.
    • Pick the speaker up and out of the mid-frame.
William Beale
104 Reputation
1 Guide authored
IUPUI, Team 2-1, Baechle Spring 2017 Member of IUPUI, Team 2-1, Baechle Spring 2017
IUPUI-BAECHLE-S17S2G1
4 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 10
All Time: 252
