ASUS PadFone X Power and Volume Buttons Replacement
  1. ASUS PadFone X Power and Volume Buttons Replacement, Power and Volume Buttons: step 1, image 1 of 1
    • Pry off the back cover with the blue plastic opening tool.
    • Removing the cover may require a bit of force.
  2. ASUS PadFone X Power and Volume Buttons Replacement: step 2, image 1 of 1
    • Remove thirteen 3.6mm screws using the T5 Torx Screwdriver.
  3. ASUS PadFone X Power and Volume Buttons Replacement: step 3, image 1 of 1
    • Once the screws are removed, the mid-frame can be lifted off of the phone.
  4. ASUS PadFone X Power and Volume Buttons Replacement: step 4, image 1 of 1
    Tool used on this step:
    Buy
    • Grasp the button strip with tweezers.
    • Pull the buttons upwards gently. The buttons should remove easily.
  5. ASUS PadFone X Power and Volume Buttons Replacement: step 5, image 1 of 1
    • Use the blue plastic opening tool to disconnect the orange sensor strip.
    • Applying too much force may damage the connector.
  6. ASUS PadFone X Power and Volume Buttons Replacement: step 6, image 1 of 1
    • Grasp the sensor with the tweezers.
    • Pull outwards away from the phone.
    • The sensor is held on by adhesive. You will need to apply some force when removing.
Madeline Dement
114 Reputation
1 Guide authored
IUPUI, Team 2-1, Baechle Spring 2017 Member of IUPUI, Team 2-1, Baechle Spring 2017
IUPUI-BAECHLE-S17S2G1
4 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 267
