ASUS FonePad 7 Vetro/Touch Replacement
  1. ASUS FonePad 7 Vetro/Touch Replacement, Rear Panel: step 1, image 1 of 2 ASUS FonePad 7 Vetro/Touch Replacement, Rear Panel: step 1, image 2 of 2
    • Make sure your device is turned off. Then with a plastic opening tool, carefully remove the back panel by carefully working your way around the perimeter.
  2. ASUS FonePad 7 Vetro/Touch Replacement, Battery: step 2, image 1 of 2 ASUS FonePad 7 Vetro/Touch Replacement, Battery: step 2, image 2 of 2
    • Remove adesive strips.
    • Disconnect the battery connectors by carefully pulling down on them using a spudger or plastic opening tool.
  3. ASUS FonePad 7 Vetro/Touch Replacement, Battery: step 3, image 1 of 3 ASUS FonePad 7 Vetro/Touch Replacement, Battery: step 3, image 2 of 3 ASUS FonePad 7 Vetro/Touch Replacement, Battery: step 3, image 3 of 3
    • Disconnect Touch Connectors using a spudger or plastic opener tool.
    • Disconnect the ZIF connectors holding the battery.
    • You can also use your hand to remove ZIF connectors.
    • ZIF connectors are delicate so be careful when you are removing them.
  4. ASUS FonePad 7 Vetro/Touch Replacement, Remove Battery: step 4, image 1 of 1
    • Using a plastic opening tool carefully pry the battery loose. The battery is glued to the pad; slight pressure will be needed to remove the battery.
  5. ASUS FonePad 7 Vetro/Touch Replacement, Power Management: step 5, image 1 of 2 ASUS FonePad 7 Vetro/Touch Replacement, Power Management: step 5, image 2 of 2
    • Disconnect cable
    • Remove the two Philips #0 screws from the power management board
    • Remove Philips #0 screw
  6. ASUS FonePad 7 Vetro/Touch Replacement, MotherBoard: step 6, image 1 of 2 ASUS FonePad 7 Vetro/Touch Replacement, MotherBoard: step 6, image 2 of 2
    • Remove GPS antenna with a spudger.
    • Disconnect the connector
  7. ASUS FonePad 7 Vetro/Touch Replacement, Power and Volume Buttons: step 7, image 1 of 3 ASUS FonePad 7 Vetro/Touch Replacement, Power and Volume Buttons: step 7, image 2 of 3 ASUS FonePad 7 Vetro/Touch Replacement, Power and Volume Buttons: step 7, image 3 of 3
    • Remove the power and volume connector
  8. ASUS FonePad 7 Vetro/Touch Replacement, Earpiece: step 8, image 1 of 2 ASUS FonePad 7 Vetro/Touch Replacement, Earpiece: step 8, image 2 of 2
    • Disconnect Earpiece connector
  9. ASUS FonePad 7 Vetro/Touch Replacement, Display Cable: step 9, image 1 of 2 ASUS FonePad 7 Vetro/Touch Replacement, Display Cable: step 9, image 2 of 2
    • Remove the Display connector from motherboard.
  10. ASUS FonePad 7 Vetro/Touch Replacement, MotherBoard: step 10, image 1 of 1
    • Remove 4screw Philips #0 from motherboard
  11. ASUS FonePad 7 Vetro/Touch Replacement, Components: step 11, image 1 of 3 ASUS FonePad 7 Vetro/Touch Replacement, Components: step 11, image 2 of 3 ASUS FonePad 7 Vetro/Touch Replacement, Components: step 11, image 3 of 3
    • Remove Components
  12. ASUS FonePad 7 Vetro/Touch Replacement, Remove Glass (TouchScreen): step 12, image 1 of 2 ASUS FonePad 7 Vetro/Touch Replacement, Remove Glass (TouchScreen): step 12, image 2 of 2
    • Inserisci qui la competenza.
  13. ASUS FonePad 7 Vetro/Touch Replacement, Replace with new Glass. Good Job ;): step 13, image 1 of 1
Per rimontare il dispositivo, segui queste istruzioni in ordine inverso.
4 other people completed this guide.
Andrew
141 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 20
All Time: 3,210
