AMD Radeon RX 580 repaste and fan replacement.
  1. AMD Radeon RX 580 repaste and fan replacement., Changing fans: step 1, image 1 of 3 AMD Radeon RX 580 repaste and fan replacement., Changing fans: step 1, image 2 of 3 AMD Radeon RX 580 repaste and fan replacement., Changing fans: step 1, image 3 of 3
    • Unplug the 2 connectors on the corner of the card.
    • Unscrew the shroud screws circled blue and lift up from the slot side pasing tabs between fan blades.
    • Remove the screw securing the power cable and bend away 2 metal tabs on the heat sink.
    • Remove fan screws circled red.
  2. AMD Radeon RX 580 repaste and fan replacement., Thermal paste and pads.: step 2, image 1 of 3 AMD Radeon RX 580 repaste and fan replacement., Thermal paste and pads.: step 2, image 2 of 3 AMD Radeon RX 580 repaste and fan replacement., Thermal paste and pads.: step 2, image 3 of 3
    • Red screws hold the heat sink.
    • With heat sink removed the last connector can be unplugged.
    • Remove blue screws to get to the thermal pads.
Ivan
85 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 65
All Time: 409
