AARP RealPad MA7BX2 Motherboard Replacement
  1. AARP RealPad MA7BX2 Motherboard Replacement, Back Cover: step 1, image 1 of 2 AARP RealPad MA7BX2 Motherboard Replacement, Back Cover: step 1, image 2 of 2
    • Loosen the back cover using the suction cup.
    • Pull up on the center of the back with the suction cup.
    • Pull up on all four corners of the back with the suction cup.
  2. AARP RealPad MA7BX2 Motherboard Replacement: step 2, image 1 of 1
    • Remove the back cover by gently placing the small opening tool in the crevice created by loosening the back.
    • Slide the opening tool around the edges of the device.
    • Wedge it open using the opening tool.
    • Use the suction cup again if you're having trouble removing the back cover.
  3. AARP RealPad MA7BX2 Motherboard Replacement: step 3, image 1 of 2 AARP RealPad MA7BX2 Motherboard Replacement: step 3, image 2 of 2
    • The black tape is stuck to delicate wires; remove with caution.
    • Peel off the silver tape.
    • Gently pull off the black tape.
  4. AARP RealPad MA7BX2 Motherboard Replacement: step 4, image 1 of 2 AARP RealPad MA7BX2 Motherboard Replacement: step 4, image 2 of 2
    • Using a JIS #000 screwdriver, remove the two 2.5 mm screws.
  5. AARP RealPad MA7BX2 Motherboard Replacement: step 5, image 1 of 2 AARP RealPad MA7BX2 Motherboard Replacement: step 5, image 2 of 2
    • Lift off the black audio cover.
  6. AARP RealPad MA7BX2 Motherboard Replacement, Motherboard: step 6, image 1 of 2 AARP RealPad MA7BX2 Motherboard Replacement, Motherboard: step 6, image 2 of 2
    • Remove the two JIS #000 screws.
  7. AARP RealPad MA7BX2 Motherboard Replacement: step 7, image 1 of 2 AARP RealPad MA7BX2 Motherboard Replacement: step 7, image 2 of 2
    • Flip up the small black connectors using a spudger or your nails.
    • Be careful when flipping them up. Too much force can cause them to break.
  8. AARP RealPad MA7BX2 Motherboard Replacement: step 8, image 1 of 1
    • Remove battery.
    • Removing the battery may need some force. Be careful as to not break anything.
  9. AARP RealPad MA7BX2 Motherboard Replacement: step 9, image 1 of 2 AARP RealPad MA7BX2 Motherboard Replacement: step 9, image 2 of 2
    Tool used on this step:
    Buy
    • Use the tweezers to loosen up the sides of speakers by going into the gaps, before picking it up.
    • There are magnets holding down the speakers. Be careful as to not pick them up with the speakers.
    • The top of the speakers are very fragile and may fall out at the slightest touch. Be careful when picking them up.
  10. AARP RealPad MA7BX2 Motherboard Replacement: step 10, image 1 of 2 AARP RealPad MA7BX2 Motherboard Replacement: step 10, image 2 of 2
    • Remove all wire connections by sliding them out of the connectors.
    • Be careful as to not forcefully pull out anything because the wires are very delicate.
  11. AARP RealPad MA7BX2 Motherboard Replacement: step 11, image 1 of 1
    • Take off the motherboard and set it aside. Your Finished product should look like this.
One Comment
I have a realpad that's is missing all the motherboard and do y'all know where can I take to get it fix because I got it for my sweet 15 as a gift from my uncle and aunt
Luz Hernandez - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 498
