8BitDo SN30 Pro+ Controller Joystick Caps Replacement
  1. 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Remove Battery: step 1, image 1 of 3 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Remove Battery: step 1, image 2 of 3 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Remove Battery: step 1, image 3 of 3
    • Place the controller face down.
    • Remove the battery cover.
    • Remove rechargeable battery or AA batteries.
  2. 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Remove Trigger Buttons: step 2, image 1 of 2 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Remove Trigger Buttons: step 2, image 2 of 2
    • Remove L2 and R2 trigger buttons by pushing them away from the grips.
  3. 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Remove Screws: step 3, image 1 of 2 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Remove Screws: step 3, image 2 of 2
    • Use Tweezers to uncover two screws under the label in the battery compartment.
    • Use a T6 screwdriver to remove the four 7.3 mm screws securing the rear cover.
  4. 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Unclip Covers: step 4, image 1 of 3 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Unclip Covers: step 4, image 2 of 3 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Unclip Covers: step 4, image 3 of 3
    • At the end of each grip, pry apart the covers.
    • Use fingernail or opening pick to undo the two top clips.
    • One clip next to L button.
    • One clip next to R button
    • Undo the final clip between the joysticks.
  5. 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Separate Covers: step 5, image 1 of 1
    • Carefully move the rear cover away and from the front cover. Place it to the left.
    • Do not completely separate. The two halves are still attached via a white ribbon cable.
  6. 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Remove Caps: step 6, image 1 of 3 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Remove Caps: step 6, image 2 of 3 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Remove Caps: step 6, image 3 of 3
    • Grab the top and pull straight up on the joystick cap. Pulling out the caps one-by-one.
  7. 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Installing New Caps: step 7, image 1 of 3 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Installing New Caps: step 7, image 2 of 3 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Installing New Caps: step 7, image 3 of 3
    • One at a time, Orient the new cap to match the analog stick.
    • Push the cap straight down onto the analog stick.
    • You should hear the click of the stick button
6 other people completed this guide.
Brian W
1,290 Reputation
8 Guides authored
3 Comments
Was wondering, does other brand joystick cap other than 8bitdo (eg:ps4, ps5, xbox one) fits ?
Lee Han Chang - Reply
looks like PS5 hole size and cone shape. Confirmation needed.
Gustavo Klein Martins -
Did you manage to find a replacement? Looking for an alternative as well since 8bitdo doesn't ship here.
Joseph Johansson - Reply
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 71
All Time: 2,671
