4Sight 9 Screen Replacement
  1. 4Sight 9 Screen Replacement, Cover: step 1, image 1 of 2 4Sight 9 Screen Replacement, Cover: step 1, image 2 of 2
    • Place the tablet on its side so that the two screws are facing upward.
    • Remove two 1 mm screws from the left side of the tablet using a Phillips #00 screwdriver.
  2. 4Sight 9 Screen Replacement: step 2, image 1 of 1
    • Pry the case away from the device slowly by sliding a plastic opening tool along the device.
    • Once loosened, use your hands to separate the case from the device.
  3. 4Sight 9 Screen Replacement: step 3, image 1 of 2 4Sight 9 Screen Replacement: step 3, image 2 of 2
    • Hold the positive and negative wires as close as possible to the speaker.
    • Use an opening tool and fingers to simultaneously lift the speaker from the cover.
  4. 4Sight 9 Screen Replacement, Battery: step 4, image 1 of 1
    • Use soldering gun to remove the positive and negative wires connecting the battery to the circuit board.
    • For a complete guide on how to solder, click here.
  5. 4Sight 9 Screen Replacement: step 5, image 1 of 2 4Sight 9 Screen Replacement: step 5, image 2 of 2
    • Insert plastic prying tool under upper-hand corner of battery and slide back and forth.
    • Once loosened, insert plastic prying tool under lower-hand corner and repeat sliding action.
    • Repeat previous actions until battery comes loose from device.
  6. 4Sight 9 Screen Replacement, Screen: step 6, image 1 of 2 4Sight 9 Screen Replacement, Screen: step 6, image 2 of 2
    • Grip the ribbon located at the far end of the circuit board with a plastic spudger tool.
    • Put pressure on the connector until the clasp comes undone.
    • Gently pull up on electrical ribbon until it disconnects from circuit board.
  7. 4Sight 9 Screen Replacement: step 7, image 1 of 2 4Sight 9 Screen Replacement: step 7, image 2 of 2
    • Remove the second electrical ribbon from the motherboard using the same technique used to remove first ribbon.
  8. 4Sight 9 Screen Replacement: step 8, image 1 of 1
    • Using #00 Phillips Screwdriver, remove the four 1mm screws holding the circuit board to the device.
  9. 4Sight 9 Screen Replacement: step 9, image 1 of 2 4Sight 9 Screen Replacement: step 9, image 2 of 2
    • With fingers, grip the green Wi-Fi connector.
    • Gently pull up on connector to remove tape holding the connector in place.
  10. 4Sight 9 Screen Replacement: step 10, image 1 of 2 4Sight 9 Screen Replacement: step 10, image 2 of 2
    • With the motherboard facing you, look to the bottom left corner, pull on the camera to completely free the motherboard.
  11. 4Sight 9 Screen Replacement: step 11, image 1 of 1
    • Using your fingers, gently lift the motherboard and battery.
  12. 4Sight 9 Screen Replacement: step 12, image 1 of 3 4Sight 9 Screen Replacement: step 12, image 2 of 3 4Sight 9 Screen Replacement: step 12, image 3 of 3
    • Insert plastic prying tool under screen and exert pressure, pulling upward.
    • Repeat this step around each corner of the screen until it pops off.
    • Ensure screen is free from all black tabs holding it in place.
  13. 4Sight 9 Screen Replacement: step 13, image 1 of 1
    • Place heating pad on glass frame in order to loosen adhesive for 3 to 5 minutes
    • Remove plastic film from glass frame
7 other people completed this guide.
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 15
All Time: 2,920
