Introduction
Anticipate this process to take 15 to 20 minutes. Be sure to have a cleared out area. You will need several different tools including a plastic prying tool, 1mm screwdriver and heating pad. This process is fairly difficult.
Place the tablet on its side so that the two screws are facing upward.
Remove two 1 mm screws from the left side of the tablet using a Phillips #00 screwdriver.
Use soldering gun to remove the positive and negative wires connecting the battery to the circuit board.
Insert plastic prying tool under screen and exert pressure, pulling upward.
Repeat this strep around each corner of screen until it pops off.
4 other people completed this guide.
