2019 Hyundai Kona and Santa Fe Key Fob Battery Replacement
  1. 2019 Hyundai Kona and Santa Fe Key Fob Battery Replacement, Battery: step 1, image 1 of 2 2019 Hyundai Kona and Santa Fe Key Fob Battery Replacement, Battery: step 1, image 2 of 2
    • Press the button or slide the groove to release the emergency key.
  2. 2019 Hyundai Kona and Santa Fe Key Fob Battery Replacement: step 2, image 1 of 2 2019 Hyundai Kona and Santa Fe Key Fob Battery Replacement: step 2, image 2 of 2
    • After removing the key blade, locate the slot or indentation.
    • Insert a flathead into the slot and gently twist to open the key fob.
  3. 2019 Hyundai Kona and Santa Fe Key Fob Battery Replacement: step 3, image 1 of 2 2019 Hyundai Kona and Santa Fe Key Fob Battery Replacement: step 3, image 2 of 2
    • Carefully lift the cover to reveal the internal components.
  4. 2019 Hyundai Kona and Santa Fe Key Fob Battery Replacement: step 4, image 1 of 1
    • Use a non-metallic tool or your hand to gently pry out the old battery.
    • Dispose of the old battery following local regulations.
  5. 2019 Hyundai Kona and Santa Fe Key Fob Battery Replacement: step 5, image 1 of 1
    • Place the new battery into the designated slot with the correct polarity.
    • Ensure the battery is securely in place.
  6. 2019 Hyundai Kona and Santa Fe Key Fob Battery Replacement: step 6, image 1 of 2 2019 Hyundai Kona and Santa Fe Key Fob Battery Replacement: step 6, image 2 of 2
    • Align the cover with the key fob and press down to snap it into place.
    • Ensure the key fob is securely closed.
    • Slide the key blade back into its slot until it clicks into place.
    • Press any button on the key fob to verify that the new battery is functioning.
    • If the light blinks on the front of the fob key, the battery replacement is successful.
sepi
145 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 4
Past 7 Days: 36
Past 30 Days: 156
All Time: 611
