2018 Toyota Corolla LE Battery Replacement
  1. 2018 Toyota Corolla LE Battery Replacement, Battery: step 1, image 1 of 1
    • Caution: Wear gloves and a mask as a basic safety precaution to avoid inhaling or touching toxins which may be harmful to your lungs.
    • Car batteries have a voltage comparable to small Duracell batteries; don't work in fear of being shocked.
    • Open the hood and locate your battery.
  2. 2018 Toyota Corolla LE Battery Replacement: step 2, image 1 of 1
    • Remove the screws from the brace securing the battery.
  3. 2018 Toyota Corolla LE Battery Replacement: step 3, image 1 of 3 2018 Toyota Corolla LE Battery Replacement: step 3, image 2 of 3 2018 Toyota Corolla LE Battery Replacement: step 3, image 3 of 3
    • Disconnect the connector on the right with no coloring or cap.
    • Remove the vertically facing screw to disconnect the battery.
    • Loosen the clamp on the side directly connected to the battery.
    • Move both away from the battery once they've been disconnected/loosened enough to disconnect.
  4. 2018 Toyota Corolla LE Battery Replacement: step 4, image 1 of 3 2018 Toyota Corolla LE Battery Replacement: step 4, image 2 of 3 2018 Toyota Corolla LE Battery Replacement: step 4, image 3 of 3
    • After removing the red cap on the second connector follow the same process you did with the right.
    • Remove the vertical screw first.
    • Loosen the horizontal screw on the side in order to fully free the battery.
  5. 2018 Toyota Corolla LE Battery Replacement: step 5, image 1 of 3 2018 Toyota Corolla LE Battery Replacement: step 5, image 2 of 3 2018 Toyota Corolla LE Battery Replacement: step 5, image 3 of 3
    • Car batteries are quite heavy so get ready to give a good lift.
    • Ensure you have a good grip on both ends and pull up both sides at once; you don't want the battery to tilt to one side
  6. 2018 Toyota Corolla LE Battery Replacement: step 6, image 1 of 2 2018 Toyota Corolla LE Battery Replacement: step 6, image 2 of 2
    • Pull out the tray that was holding the battery.
    • Clean off any dust or corrosion formed from use.
    • Place it back using the points on it to indicate how to fit it back in.
0 Comments
Past 24 Hours: 0
Past 7 Days: 16
Past 30 Days: 79
All Time: 354
