2016 Ford Fiesta S High Beam Replacement
  1. 2016 Ford Fiesta S High Beam Replacement, High Beam: step 1, image 1 of 3 2016 Ford Fiesta S High Beam Replacement, High Beam: step 1, image 2 of 3 2016 Ford Fiesta S High Beam Replacement, High Beam: step 1, image 3 of 3
    • Do not open your hood when there are high winds.
    • Verify that the handbrake is on and the ignition is off.
    • Wait 10 minutes for the engine to cool before opening the hood.
    • Locate the release hatch and pull it towards you.
    • Lift the hood slightly and feel for the release catch, then slide it to the left.
    • Lift the hood and prop it up with the strut.
  2. 2016 Ford Fiesta S High Beam Replacement: step 2, image 1 of 1
    • Remove the lower retaining screw with a Phillips screwdriver.
    • Keep the pop rivet in a safe place to help with the reassembling process.
  3. 2016 Ford Fiesta S High Beam Replacement: step 3, image 1 of 1
    • Remove the front screw with a flat head screwdriver.
    • Keep the screw in a safe place to help with the reassembling process.
  4. 2016 Ford Fiesta S High Beam Replacement: step 4, image 1 of 1
    • Remove the upper retaining screw in the back with a Phillips screwdriver.
  5. 2016 Ford Fiesta S High Beam Replacement: step 5, image 1 of 1
    • Lift the headlight up and off the mounting point clip.
    • Squeeze the clips and pull the electrical connector out.
    • Remove the headlight from the back first for easier removal.
    • Place the headlight on a flat, secure surface.
  6. 2016 Ford Fiesta S High Beam Replacement: step 6, image 1 of 1
    • Locate the high beam cover in the middle of the headlight.
    • Turn the cover counterclockwise and remove it.
  7. 2016 Ford Fiesta S High Beam Replacement: step 7, image 1 of 2 2016 Ford Fiesta S High Beam Replacement: step 7, image 2 of 2
    • Turn the bulb and the electrical connector counterclockwise and remove them.
  8. 2016 Ford Fiesta S High Beam Replacement: step 8, image 1 of 2 2016 Ford Fiesta S High Beam Replacement: step 8, image 2 of 2
    • Make sure you do not touch the glass surface of the bulb with your bare hands; if the oil from your hands touches the glass surface, it may cause the bulb to heat up and burn out.
    • Clean the bulb with rubbing alcohol to remove any oils that may be on the bulb then remove any traces of alcohol with a dry cloth before reinstalling the bulb.
    • Screw in the new bulb clockwise to secure it in place.
    • Put the electrical connector back on.
    • Hold the bulb by its base and insert it back into the back of the headlight.
    • Turn your headlights on to test if the headlight works properly.
    • Screw the cover back on and secure it.
  9. 2016 Ford Fiesta S High Beam Replacement: step 9, image 1 of 2 2016 Ford Fiesta S High Beam Replacement: step 9, image 2 of 2
    • Position the headlight back into place.
    • Reclip the mounting point clip.
    • Position the headlight so that the front piece is under the pop rivet hole that was removed in Step 2.
  10. 2016 Ford Fiesta S High Beam Replacement: step 10, image 1 of 1
    • Screw back in the lower retaining screw.
  11. 2016 Ford Fiesta S High Beam Replacement: step 11, image 1 of 1
    • Screw back in the middle screw with a flathead screwdriver.
  12. 2016 Ford Fiesta S High Beam Replacement: step 12, image 1 of 1
    • Screw back in the upper retaining screw to secure the back of the headlight.
  13. 2016 Ford Fiesta S High Beam Replacement: step 13, image 1 of 1
    • Plug the electrical connector to the back of the headlight.
  14. 2016 Ford Fiesta S High Beam Replacement: step 14, image 1 of 1
    • Hold the hood with one hand and release the strut with the other.
    • Let the hood down gently until 30 cm from the body, then drop it to lock the hood.
    • Pushing on the hood to lock it might cause dents.
Finish Line
3 other people completed this guide.
2 Comments
buen tutorial, estaria excelente agregar un video, gracias por el aporte
oslec “Netmit” burg - Reply
Parabéns, muito bom a explicação
Edipeixe - Reply
Past 24 Hours: 5
Past 7 Days: 36
Past 30 Days: 180
All Time: 6,145
