2015-2023 Ford Mustang Taillight Assembly Replacement
  1. 2015-2023 Ford Mustang Taillight Assembly Replacement, Taillight Assembly: step 1, image 1 of 3 2015-2023 Ford Mustang Taillight Assembly Replacement, Taillight Assembly: step 1, image 2 of 3 2015-2023 Ford Mustang Taillight Assembly Replacement, Taillight Assembly: step 1, image 3 of 3
    • Locate the two knobs inside the car's trunk.
    • Unscrew both knobs using your hand.
  2. 2015-2023 Ford Mustang Taillight Assembly Replacement: step 2, image 1 of 3 2015-2023 Ford Mustang Taillight Assembly Replacement: step 2, image 2 of 3 2015-2023 Ford Mustang Taillight Assembly Replacement: step 2, image 3 of 3
    • Locate the highlighted plastic rivet inside the car's trunk.
    • Place your trim removal tool under the rivet.
    • Pop the rivet out using the trim removal tool.
  3. 2015-2023 Ford Mustang Taillight Assembly Replacement: step 3, image 1 of 3 2015-2023 Ford Mustang Taillight Assembly Replacement: step 3, image 2 of 3 2015-2023 Ford Mustang Taillight Assembly Replacement: step 3, image 3 of 3
    • Grab the plastic trim and move it out over the bolts sticking out.
    • Move the carpet with your hands so that it is above the plastic trim.
    • The carpet should be held in place by the plastic trim.
  4. 2015-2023 Ford Mustang Taillight Assembly Replacement: step 4, image 1 of 3 2015-2023 Ford Mustang Taillight Assembly Replacement: step 4, image 2 of 3 2015-2023 Ford Mustang Taillight Assembly Replacement: step 4, image 3 of 3
    • Locate the wiring harness
    • Unplug the wiring harness by pressing down on the securing tab and separating them.
    • The harness should separate easily, do not force it or else damage may occur.
  5. 2015-2023 Ford Mustang Taillight Assembly Replacement: step 5, image 1 of 3 2015-2023 Ford Mustang Taillight Assembly Replacement: step 5, image 2 of 3 2015-2023 Ford Mustang Taillight Assembly Replacement: step 5, image 3 of 3
    • Locate the three 10 mm hex nuts behind the carpet.
    • Remove the 10 mm hex nuts using a 10 mm wrench.
  6. 2015-2023 Ford Mustang Taillight Assembly Replacement: step 6, image 1 of 3 2015-2023 Ford Mustang Taillight Assembly Replacement: step 6, image 2 of 3 2015-2023 Ford Mustang Taillight Assembly Replacement: step 6, image 3 of 3
    • Pull the taillight assembly out towards the direction of your body.
    • Force may be required.
    • Lift up on the rubber seal and pull out the wiring harness.
  7. 2015-2023 Ford Mustang Taillight Assembly Replacement: step 7, image 1 of 3 2015-2023 Ford Mustang Taillight Assembly Replacement: step 7, image 2 of 3 2015-2023 Ford Mustang Taillight Assembly Replacement: step 7, image 3 of 3
    • Route the wiring harness of the new taillight assembly into the highlighted hole.
    • Make sure that the rubber is properly sealing to prevent moisture from entering the car.
    • Slide in the new taillight assembly.
    • Align the three threads on the back of the taillight assembly with the three holes on the bumper.
To secure the taillight assembly and trim, follow steps 1 through 5 in reverse order
gewest
145 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 14
Past 30 Days: 37
All Time: 166
