2014 Toyota Corolla Model L Cabin Air Filter Replacement
  1. 2014 Toyota Corolla Model L Cabin Air Filter Replacement, Cabin Air Filter: step 1, image 1 of 1
    • Remove all of the Items in your car's glove box.
  2. 2014 Toyota Corolla Model L Cabin Air Filter Replacement: step 2, image 1 of 2 2014 Toyota Corolla Model L Cabin Air Filter Replacement: step 2, image 2 of 2
    • Pull the glove box damper apart from screw located on the right side of the glove box.
  3. 2014 Toyota Corolla Model L Cabin Air Filter Replacement: step 3, image 1 of 2 2014 Toyota Corolla Model L Cabin Air Filter Replacement: step 3, image 2 of 2
    • Push the two sides of the glovebox inwards towards each other and gently bring the glovebox down all the way.
    • The glovebox will completely detach.
  4. 2014 Toyota Corolla Model L Cabin Air Filter Replacement: step 4, image 1 of 3 2014 Toyota Corolla Model L Cabin Air Filter Replacement: step 4, image 2 of 3 2014 Toyota Corolla Model L Cabin Air Filter Replacement: step 4, image 3 of 3
    • Locate the cabin air filter which has a black cap.
    • Push the tab on the right side of the black cap and push it towards the left to remove it.
  5. 2014 Toyota Corolla Model L Cabin Air Filter Replacement: step 5, image 1 of 1
    • Remove and replace the air filter with the arrow pointing the same direction as your last air filter which will be downwards.
    • CAUTION: Your air filter will be filled with dust, leaves, and dirt. You may want to wear a mask to not inhale these harmful items.
  6. 2014 Toyota Corolla Model L Cabin Air Filter Replacement: step 6, image 1 of 1
    • Put the black top of the filter back into place and click it back into place.
  7. 2014 Toyota Corolla Model L Cabin Air Filter Replacement: step 7, image 1 of 2 2014 Toyota Corolla Model L Cabin Air Filter Replacement: step 7, image 2 of 2
    • Attach the black hinges located on the bottom of the glovebox back into place.
    • Lift the glovebox back into its original position.
  8. 2014 Toyota Corolla Model L Cabin Air Filter Replacement: step 8, image 1 of 2 2014 Toyota Corolla Model L Cabin Air Filter Replacement: step 8, image 2 of 2
    • Push the glove box damper back into the screw.
Victor_
157 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 37
Past 30 Days: 99
All Time: 336
