2014 Buick Encore Air Intake Filter Replacement
  1. 2014 Buick Encore Air Intake Filter Replacement, Air Intake Filter: step 1, image 1 of 3 2014 Buick Encore Air Intake Filter Replacement, Air Intake Filter: step 1, image 2 of 3 2014 Buick Encore Air Intake Filter Replacement, Air Intake Filter: step 1, image 3 of 3
    • Make sure that the vehicle is turned off before proceeding.
    • Pull the hood release latch under the steering wheel on driver's side.
  2. 2014 Buick Encore Air Intake Filter Replacement: step 2, image 1 of 2 2014 Buick Encore Air Intake Filter Replacement: step 2, image 2 of 2
    • Push the hood latch with your thumb of your right hand.
    • Lift the hood with your left hand to open the hood.
  3. 2014 Buick Encore Air Intake Filter Replacement: step 3, image 1 of 3 2014 Buick Encore Air Intake Filter Replacement: step 3, image 2 of 3 2014 Buick Encore Air Intake Filter Replacement: step 3, image 3 of 3
    • Place the hood prop to the prop hole to secure the hood from falling.
  4. 2014 Buick Encore Air Intake Filter Replacement: step 4, image 1 of 2 2014 Buick Encore Air Intake Filter Replacement: step 4, image 2 of 2
    • Locate the air filter.
  5. 2014 Buick Encore Air Intake Filter Replacement: step 5, image 1 of 3 2014 Buick Encore Air Intake Filter Replacement: step 5, image 2 of 3 2014 Buick Encore Air Intake Filter Replacement: step 5, image 3 of 3
    • Remove the two 5 mm screws from the air filter cover with a Phillips #2 Screwdriver.
  6. 2014 Buick Encore Air Intake Filter Replacement: step 6, image 1 of 2 2014 Buick Encore Air Intake Filter Replacement: step 6, image 2 of 2
    • Pull the air filter cover off.
  7. 2014 Buick Encore Air Intake Filter Replacement: step 7, image 1 of 3 2014 Buick Encore Air Intake Filter Replacement: step 7, image 2 of 3 2014 Buick Encore Air Intake Filter Replacement: step 7, image 3 of 3
    • Remove the old air filter.
  8. 2014 Buick Encore Air Intake Filter Replacement: step 8, image 1 of 3 2014 Buick Encore Air Intake Filter Replacement: step 8, image 2 of 3 2014 Buick Encore Air Intake Filter Replacement: step 8, image 3 of 3
    • Place the new air filter in the filter box.
  9. 2014 Buick Encore Air Intake Filter Replacement: step 9, image 1 of 2 2014 Buick Encore Air Intake Filter Replacement: step 9, image 2 of 2
    • Place the cover back to original place.
    • Make sure the hinges on the right side secure the cover.
  10. 2014 Buick Encore Air Intake Filter Replacement: step 10, image 1 of 1
    • Insert the two 5 mm screws, and tighten them with a Phillips #2 Screwdriver.
  11. 2014 Buick Encore Air Intake Filter Replacement: step 11, image 1 of 3 2014 Buick Encore Air Intake Filter Replacement: step 11, image 2 of 3 2014 Buick Encore Air Intake Filter Replacement: step 11, image 3 of 3
    • Remove the hood prop from the hole.
    • Secure the hood prop with the hood prop clip.
    • Close the hood.
Allen Tenedero
193 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 36
All Time: 385
