2013 Lexus IS250 Front Dome Light Replacement
  1. 2013 Lexus IS250 Front Dome Light Replacement, Headlight Dome: step 1, image 1 of 2 2013 Lexus IS250 Front Dome Light Replacement, Headlight Dome: step 1, image 2 of 2
    • Open the glasses compartment located near the front dome light. This is usually a straightforward latch or button release.
  2. 2013 Lexus IS250 Front Dome Light Replacement: step 2, image 1 of 3 2013 Lexus IS250 Front Dome Light Replacement: step 2, image 2 of 3 2013 Lexus IS250 Front Dome Light Replacement: step 2, image 3 of 3
    • Locate two housings inisde the compartment and gently pry them open using a flathead screwdriver. Take care not to damage the surrounding plastic.
  3. 2013 Lexus IS250 Front Dome Light Replacement: step 3, image 1 of 3 2013 Lexus IS250 Front Dome Light Replacement: step 3, image 2 of 3 2013 Lexus IS250 Front Dome Light Replacement: step 3, image 3 of 3
    • Utilize a star screwdriver to remove the screws holding the front dome light in place. Ensure a steady hand to prevent any accidental dropping of screws.
  4. 2013 Lexus IS250 Front Dome Light Replacement: step 4, image 1 of 3 2013 Lexus IS250 Front Dome Light Replacement: step 4, image 2 of 3 2013 Lexus IS250 Front Dome Light Replacement: step 4, image 3 of 3
    • With both hands wiggle both sides of the dome. Apply a bit of force at the top to release it from its position. Be cautious to not break the plastic clips securing it.
  5. 2013 Lexus IS250 Front Dome Light Replacement: step 5, image 1 of 3 2013 Lexus IS250 Front Dome Light Replacement: step 5, image 2 of 3 2013 Lexus IS250 Front Dome Light Replacement: step 5, image 3 of 3
    • Inside, youll find two bulbs on both ends. Twist them to unlock and carefully remove.
  6. 2013 Lexus IS250 Front Dome Light Replacement: step 6, image 1 of 2 2013 Lexus IS250 Front Dome Light Replacement: step 6, image 2 of 2
    • Carefully remove bulb. Recommended to use gloves as it can be difficult to get a grip.
  7. 2013 Lexus IS250 Front Dome Light Replacement: step 7, image 1 of 3 2013 Lexus IS250 Front Dome Light Replacement: step 7, image 2 of 3 2013 Lexus IS250 Front Dome Light Replacement: step 7, image 3 of 3
    • Replace these bulbs with LED alternatives, inserting them and securing by twisting.
  8. 2013 Lexus IS250 Front Dome Light Replacement: step 8, image 1 of 1
    • Confirm that the bulbs are functioning by checking if the lights turn on. If not double check the alignment of the bulbs to ensure proper contact.
    • Carefully place the dome back into its original position. Ensure it aligns correctly with the plastic tips. Apply gentle pressure until it clicks back into place.
Christian
157 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 34
All Time: 111
