2012-2018 Nissan Versa Note Headlight Bulb Replacement
  1. 2012-2018 Nissan Versa Note Headlight Bulb Replacement, Headlight Bulb: step 1, image 1 of 2 2012-2018 Nissan Versa Note Headlight Bulb Replacement, Headlight Bulb: step 1, image 2 of 2
    • Pull the hood lever.
  2. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: step 2, image 1 of 1
    • Push the lever underneath the hood to the left.
    • The lever is located in the center underneath the hood.
  3. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: step 3, image 1 of 1
    • Pull up the hood.
  4. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: step 4, image 1 of 1
    • Insert the support rod into the slot.
    • The stent is located to the right of the hood.
    • The slot is located in the underside of the hood to the right.
  5. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: step 5, image 1 of 2 2012-2018 Nissan Versa Note Headlight Bulb Replacement: step 5, image 2 of 2
    • Pull out the connector from the bulb.
    • Depending on the make of your vehicle, you may have push the tab on the connector that reads "push" before pulling out the connector.
  6. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: step 6, image 1 of 1
    • Twist the plastic ring out from the bulb.
  7. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: step 7, image 1 of 2 2012-2018 Nissan Versa Note Headlight Bulb Replacement: step 7, image 2 of 2
    • Pull out the old bulb.
    • High pressure halogen gas is sealed inside the halogen bulb. The bulb may break if the glass envelope is scratched or the bulb is dropped.
    • When handling the bulb, do not touch the glass envelope.
  8. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: step 8, image 1 of 2 2012-2018 Nissan Versa Note Headlight Bulb Replacement: step 8, image 2 of 2
    • Insert the replacement bulb.
  9. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: step 9, image 1 of 1
    • Twist the plastic ring back onto the bulb.
  10. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: step 10, image 1 of 2 2012-2018 Nissan Versa Note Headlight Bulb Replacement: step 10, image 2 of 2
    • Insert the connector into the bulb.
Finish Line
2 other people completed this guide.
0 Comments
Past 24 Hours: 5
Past 7 Days: 65
Past 30 Days: 282
All Time: 12,502
