2011 Scion Tc Blower Motor Replacement
  1. 2011 Scion Tc Blower Motor Replacement, Blower Motor: step 1, image 1 of 1
    • Locate your blower motor. Your blower motor should be below the glovebox.
  2. 2011 Scion Tc Blower Motor Replacement: step 2, image 1 of 1
    • Remove the three 2 mm screws that secure the blower motor.
  3. 2011 Scion Tc Blower Motor Replacement: step 3, image 1 of 1
    • Remove the two 1 mm Phillips #0 screws that secure the blower motor wiring harness.
  4. 2011 Scion Tc Blower Motor Replacement: step 4, image 1 of 2 2011 Scion Tc Blower Motor Replacement: step 4, image 2 of 2
    • Disconnect the sensor that is connect to the blower motor.
    • The sensor should have a click and carefully remove it upwards.
  5. 2011 Scion Tc Blower Motor Replacement: step 5, image 1 of 2 2011 Scion Tc Blower Motor Replacement: step 5, image 2 of 2
    • Put the new blower motor in place, and secure it with the three 2 mm Phillips #0 screws.
  6. 2011 Scion Tc Blower Motor Replacement: step 6, image 1 of 1
    • Tighten the two 1 mm screws to the wiring harness.
  7. 2011 Scion Tc Blower Motor Replacement: step 7, image 1 of 1
    • Congratulations, you have successfully replaced your blower motor!
    • Once all the screws are tightened, just make sure to turn on your air to see if your blower motor works!
Jose Ruvalcaba
145 Reputation
1 Guide authored
One Comment
Is the blower motor inside of the car under the glovebox? Do I need to replace the glovebox to get to the blower motor?
Christopher Sean Harris - Reply
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 23
All Time: 1,105
