2011 Mazda 3 Car Speaker Replacement
  1. 2011 Mazda 3 Car Speaker Replacement, 2011 Mazda 3 Car Speaker: step 1, image 1 of 3 2011 Mazda 3 Car Speaker Replacement, 2011 Mazda 3 Car Speaker: step 1, image 2 of 3 2011 Mazda 3 Car Speaker Replacement, 2011 Mazda 3 Car Speaker: step 1, image 3 of 3
    • Pry the door handle cover upwards using a flathead screwdriver.
    • Remove the cover to expose the screw.
  2. 2011 Mazda 3 Car Speaker Replacement: step 2, image 1 of 2 2011 Mazda 3 Car Speaker Replacement: step 2, image 2 of 2
    • Pull the door handle towards you.
    • Insert a small flathead screwdriver between the lock and the plate.
    • Pry the plate off by applying leverage away from the lock, exposing the second screw.
  3. 2011 Mazda 3 Car Speaker Replacement: step 3, image 1 of 2 2011 Mazda 3 Car Speaker Replacement: step 3, image 2 of 2
    • Remove both screws with a Phillips #1 screwdriver.
    • The screws are 12mm Phillip's head. Part number (9986-50-516S).
  4. 2011 Mazda 3 Car Speaker Replacement: step 4, image 1 of 1
    • Pry the door cover away from the frame using a heavy-duty spudger.
    • The door cover will not be removed entirely in this step.
    • Prying the door off takes substantial force; moving around the door's perimeter will help unhook the clips that line the panel.
  5. 2011 Mazda 3 Car Speaker Replacement: step 5, image 1 of 2 2011 Mazda 3 Car Speaker Replacement: step 5, image 2 of 2
    • Push the switch panel out from the inside of the door cover.
    • Ensure the car is off before proceeding.
    • Remove the wires connected to the panel by pressing the clips and pulling them outward.
    • Remove the door cover.
  6. 2011 Mazda 3 Car Speaker Replacement: step 6, image 1 of 1
    • Use a Phillips #1 screwdriver to remove the four screws that secure the door speaker.
    • The screws are 10mm Phillip's head. Part number (9984-50-616).
  7. 2011 Mazda 3 Car Speaker Replacement: step 7, image 1 of 1
    • Remove the wires connecting the speaker by pressing the clip and pulling it outward.
2 other people completed this guide.
0 Comments
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 90
All Time: 2,419
