2011-2013 Scion tC Radio Head Unit Replacement
  1. 2011-2013 Scion tC Radio Head Unit Replacement, Radio Head Unit: step 1, image 1 of 2 2011-2013 Scion tC Radio Head Unit Replacement, Radio Head Unit: step 1, image 2 of 2
    • Remove the dashboard panel around the radio head by pulling on the bottom of the unit.
  2. 2011-2013 Scion tC Radio Head Unit Replacement: step 2, image 1 of 2 2011-2013 Scion tC Radio Head Unit Replacement: step 2, image 2 of 2
    • Remove the wire header connected to the panel by pressing inward on the tabs.
  3. 2011-2013 Scion tC Radio Head Unit Replacement: step 3, image 1 of 1
    • Remove the four #2 12mm screws securing the head unit in the housing
  4. 2011-2013 Scion tC Radio Head Unit Replacement: step 4, image 1 of 2 2011-2013 Scion tC Radio Head Unit Replacement: step 4, image 2 of 2
    • Remove each bundle of wires that is connected to the back of the head unit.
  5. 2011-2013 Scion tC Radio Head Unit Replacement: step 5, image 1 of 2 2011-2013 Scion tC Radio Head Unit Replacement: step 5, image 2 of 2
    • Locate the metal brackets on the side of the head unit.
    • Use a Philips head screwdriver, remove the three #2 25mm screws from both support brackets on the side of the head unit
  6. 2011-2013 Scion tC Radio Head Unit Replacement: step 6, image 1 of 1
    • Screw the support brackets to the new radio head unit
    • Note that the brackets are unique to the car. They will not come with your new head unit.
2 other people completed this guide.
Dylan Smith
143 Reputation
1 Guide authored
Cal Poly, Team 8-2, Regan Spring 2015 Member of Cal Poly, Team 8-2, Regan Spring 2015
CPSU-REGAN-S15S8G2
5 Members
7 Guides authored
0 Comments
Past 24 Hours: 4
Past 7 Days: 7
Past 30 Days: 39
All Time: 7,459
