2011-2013 Scion tC Mid-Range Door Speaker Replacement
  1. 2011-2013 Scion tC Mid-Range Door Speaker Replacement, Mid-Range Door Speaker: step 1, image 1 of 1
    • Using plastic pry tool. Pry silver cover from handle.
  2. 2011-2013 Scion tC Mid-Range Door Speaker Replacement: step 2, image 1 of 1
    • Using plastic pry tool. Pry Control panel off which controls locking, unlocking and windows.
  3. 2011-2013 Scion tC Mid-Range Door Speaker Replacement: step 3, image 1 of 1
    • Un-attach white header(connector) from control panel. Push side tab on side of white connector if a little stuck.
  4. 2011-2013 Scion tC Mid-Range Door Speaker Replacement: step 4, image 1 of 1
    • Using pry tool. Pry off plastic plate in section of door lock or pull handle.
  5. 2011-2013 Scion tC Mid-Range Door Speaker Replacement: step 5, image 1 of 1
    • Remove the #4 25mm screw and the #2 25mm screw on panel with a standard Phillips Screwdriver.
  6. 2011-2013 Scion tC Mid-Range Door Speaker Replacement: step 6, image 1 of 1
    • Pry Off Full Door Panel starting at bottom and working up the side, pulling fairly hard waiting. Clicking noises are a good sign the door panel is unlocking.
  7. 2011-2013 Scion tC Mid-Range Door Speaker Replacement: step 7, image 1 of 1
    • Once door panel is free, remember to remove header from the tweeter in upper right hand corner of panel.
  8. 2011-2013 Scion tC Mid-Range Door Speaker Replacement: step 8, image 1 of 1
    • Remove bracket from door by unscrewing the two 14 mm nuts pictured here connected to the speaker unit.
  9. 2011-2013 Scion tC Mid-Range Door Speaker Replacement: step 9, image 1 of 1
    • Remove speaker from bracket by unscrewing the two #2 12mm screws using a Phillips head screwdriver.
  10. 2011-2013 Scion tC Mid-Range Door Speaker Replacement: step 10, image 1 of 1
    • Desolder wires to new speaker unit using solder wick or a desoldering tool.
    • If you don't have experience soldering, make sure to check out this soldering guide.
    • Soldering uses high temperatures. Be careful not to damage the components or injure yourself in the process.
3 other people completed this guide.
sdwelsh
187 Reputation
1 Guide authored
Cal Poly, Team 8-2, Regan Spring 2015 Member of Cal Poly, Team 8-2, Regan Spring 2015
CPSU-REGAN-S15S8G2
5 Members
7 Guides authored
One Comment
Are they 6.5 subwoofer lower door or 6×9
pauliemcfly25 - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 31
All Time: 3,869
