2011-2013 Scion tC Car Battery Replacement
  1. 2011-2013 Scion tC Car Battery Replacement, Car Battery: step 1, image 1 of 1
    • Begin by opening the hood of the car and locating the battery on the front of the driver side in the engine compartment
  2. 2011-2013 Scion tC Car Battery Replacement: step 2, image 1 of 1
    • Using a socket wrench, loosen the 2 (5/16 inch) nuts on the top of the battery support bracket
    • Remove the bracket by lifting up
  3. 2011-2013 Scion tC Car Battery Replacement: step 3, image 1 of 1
    • After removing the bracket, locate the supporting rod behind the battery
    • The rod is hooked on a hole in the metal behind the battery. Unhook the rod and remove it
  4. 2011-2013 Scion tC Car Battery Replacement: step 4, image 1 of 2 2011-2013 Scion tC Car Battery Replacement: step 4, image 2 of 2
    • Start with the negative terminal of the battery
    • Loosen the nut on the negative terminal with a 10mm socket wrench
    • Remove the wire by slightly twisting and pulling up
  5. 2011-2013 Scion tC Car Battery Replacement: step 5, image 1 of 2 2011-2013 Scion tC Car Battery Replacement: step 5, image 2 of 2
    • Remove the cap from the positive terminal of the battery
    • Using a 10mm socket wrench, loosen the nut on the positive terminal
    • Remove the wire from the positive terminal by slightly twisting and pulling up
    • Remove the battery by lifting it out of the engine compartment
Travis Michael
140 Reputation
1 Guide authored
Cal Poly, Team 8-2, Regan Spring 2015 Member of Cal Poly, Team 8-2, Regan Spring 2015
CPSU-REGAN-S15S8G2
5 Members
7 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 59
All Time: 10,756
