2011-2016 Ford Super Duty Tail Light and Bulbs Replacement
  1. 2011-2016 Ford Super Duty Tail Light and Bulbs Replacement, Tail Light and Bulbs: step 1, image 1 of 2 2011-2016 Ford Super Duty Tail Light and Bulbs Replacement, Tail Light and Bulbs: step 1, image 2 of 2
    • Locate the two 8 mm screws that attach the taillight housing to the vehicle.
  2. 2011-2016 Ford Super Duty Tail Light and Bulbs Replacement: step 2, image 1 of 2 2011-2016 Ford Super Duty Tail Light and Bulbs Replacement: step 2, image 2 of 2
    • Using a socket and ratchet wrench, remove the two screws facing the inside of the bed that you located in Step 1.
  3. 2011-2016 Ford Super Duty Tail Light and Bulbs Replacement: step 3, image 1 of 2 2011-2016 Ford Super Duty Tail Light and Bulbs Replacement: step 3, image 2 of 2
    • Pull the light housing outward at an angle away from the truck.
  4. 2011-2016 Ford Super Duty Tail Light and Bulbs Replacement: step 4, image 1 of 3 2011-2016 Ford Super Duty Tail Light and Bulbs Replacement: step 4, image 2 of 3 2011-2016 Ford Super Duty Tail Light and Bulbs Replacement: step 4, image 3 of 3
    • Twist the light socket in a counterclockwise motion to remove the bulbs.
  5. 2011-2016 Ford Super Duty Tail Light and Bulbs Replacement: step 5, image 1 of 3 2011-2016 Ford Super Duty Tail Light and Bulbs Replacement: step 5, image 2 of 3 2011-2016 Ford Super Duty Tail Light and Bulbs Replacement: step 5, image 3 of 3
    • Insert a new bulb.
    • Place the light bulb socket back in the hole and turn clockwise until it's locked in place.
  6. 2011-2016 Ford Super Duty Tail Light and Bulbs Replacement: step 6, image 1 of 3 2011-2016 Ford Super Duty Tail Light and Bulbs Replacement: step 6, image 2 of 3 2011-2016 Ford Super Duty Tail Light and Bulbs Replacement: step 6, image 3 of 3
    • Line up the taillight housing with the holes and guides, and push it into place.
  7. 2011-2016 Ford Super Duty Tail Light and Bulbs Replacement: step 7, image 1 of 3 2011-2016 Ford Super Duty Tail Light and Bulbs Replacement: step 7, image 2 of 3 2011-2016 Ford Super Duty Tail Light and Bulbs Replacement: step 7, image 3 of 3
    • Use a socket and ratchet wrench to tighten the screws back into the taillight housing.
0 Comments
Past 24 Hours: 4
Past 7 Days: 31
Past 30 Days: 148
All Time: 3,878
