2011-2017 Honda Odyssey Key Fob Battery Replacement
Video Overview
  1. 2011-2017 Honda Odyssey Key Fob Battery Replacement, Remove Mechanical Key: step 1, image 1 of 1
    • Remove the mechanical key by moving the tab on back of key & pulling out the key.
  2. 2011-2017 Honda Odyssey Key Fob Battery Replacement, Separate Shell: step 2, image 1 of 1
    • Separate the shell using a large screw driver or by using the mechanical key. The shells have a separating tab in the middle. Pry open the shell by gently twisting the screwdriver or the mechanical key into the separating tab.
  3. 2011-2017 Honda Odyssey Key Fob Battery Replacement, Remove Battery: step 3, image 1 of 1
    • Remove the battery carefully using a small screw driver.
  4. 2011-2017 Honda Odyssey Key Fob Battery Replacement, Replace Battery: step 4, image 1 of 1
    • Replace the battery. Make sure not to damage the 2 tabs holding the battery. Do not press or force the battery into its place, slide it underneath the tabs.
    • Battery : Lithium Coin Battery CR2032 3V
  5. 2011-2017 Honda Odyssey Key Fob Battery Replacement, Re-assemble Shell: step 5, image 1 of 1
    • Put the outer shell together and gently press and snap the two half's in place
  6. 2011-2017 Honda Odyssey Key Fob Battery Replacement, Mechanical key: step 6, image 1 of 1
    • Put the mechanical key back
3 other people completed this guide.
A nibeS
223 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 12
Past 7 Days: 121
Past 30 Days: 561
All Time: 15,789
