2010 Chevrolet Camaro Door Handle Interior Door Handle Replacement
Featured Document
  1. 2010 Chevrolet Camaro Door Handle Interior Door Handle Replacement, Interior Door Handle: step 1, image 1 of 3 2010 Chevrolet Camaro Door Handle Interior Door Handle Replacement, Interior Door Handle: step 1, image 2 of 3 2010 Chevrolet Camaro Door Handle Interior Door Handle Replacement, Interior Door Handle: step 1, image 3 of 3
    • Remove the five bolts that connect the door panel to the door using the T30 Torx screwdriver.
    • Use a door panel removal tool to pry out the outer edges.
    • Keep in mind the door card has up to three wire bundles attached to it. Be careful when removing it! Be prepared to support it while dealing with the wires.
  2. 2010 Chevrolet Camaro Door Handle Interior Door Handle Replacement: step 2, image 1 of 3 2010 Chevrolet Camaro Door Handle Interior Door Handle Replacement: step 2, image 2 of 3 2010 Chevrolet Camaro Door Handle Interior Door Handle Replacement: step 2, image 3 of 3
    • Use your hands to sisconnect the speaker cables from the door panel.
    • Set the door panel aside.
  3. 2010 Chevrolet Camaro Door Handle Interior Door Handle Replacement: step 3, image 1 of 3 2010 Chevrolet Camaro Door Handle Interior Door Handle Replacement: step 3, image 2 of 3 2010 Chevrolet Camaro Door Handle Interior Door Handle Replacement: step 3, image 3 of 3
    • Grab the replacement interior door handle.
    • Use the T30 Torx screwdriver to remove the single screw holding the original door handle in place.
    • Remove and replace the broken door handle the same as you disassembled it.
  4. 2010 Chevrolet Camaro Door Handle Interior Door Handle Replacement: step 4, image 1 of 3 2010 Chevrolet Camaro Door Handle Interior Door Handle Replacement: step 4, image 2 of 3 2010 Chevrolet Camaro Door Handle Interior Door Handle Replacement: step 4, image 3 of 3
    • Using the 7mm deep socket and a racketing wrench, remove the screws connecting the door panel to the handle.
    • Replace the door handle.
    • Screw the three 7mm screws back into place.
  5. 2010 Chevrolet Camaro Door Handle Interior Door Handle Replacement: step 5, image 1 of 3 2010 Chevrolet Camaro Door Handle Interior Door Handle Replacement: step 5, image 2 of 3 2010 Chevrolet Camaro Door Handle Interior Door Handle Replacement: step 5, image 3 of 3
    • Double check the connection to the door handle.
    • Inspect the new door latch to ensure it is working.
    • Check that the door is working properly.
  6. 2010 Chevrolet Camaro Door Handle Interior Door Handle Replacement: step 6, image 1 of 3 2010 Chevrolet Camaro Door Handle Interior Door Handle Replacement: step 6, image 2 of 3 2010 Chevrolet Camaro Door Handle Interior Door Handle Replacement: step 6, image 3 of 3
    • Reinstall the door panel by completing Step 1 in reverse.
    • Reconnect all the cables.
    • The interior door handle replacement functions the same as the original.
    • You have now successfully replaced a 2010 Camaro interior door handle.
To reassemble your device, follow these instructions in reverse order. Test out the door handle and if it functions the same as the original door handle.
Attached Documents
Evelyn
185 Reputation
1 Guide authored
One Comment
How does led light inside the door get its power
sylvinlittle1 - Reply
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 86
All Time: 2,341
