2010-2017 Suzuki Swift Engine Air Filter Replacement
  1. 2010-2017 Suzuki Swift Engine Air Filter Replacement, locate the filter: step 1, image 1 of 3 2010-2017 Suzuki Swift Engine Air Filter Replacement, locate the filter: step 1, image 2 of 3 2010-2017 Suzuki Swift Engine Air Filter Replacement, locate the filter: step 1, image 3 of 3
    • The filter housing is located behind the air intake.
    • Pull both clasps holding the filter housing to the air intake.
    • Push the housing back to see the filter.
  2. 2010-2017 Suzuki Swift Engine Air Filter Replacement, remove old filter: step 2, image 1 of 2 2010-2017 Suzuki Swift Engine Air Filter Replacement, remove old filter: step 2, image 2 of 2
    • Slide the old filter up and out.
    • Remember the only square corner of the filter is in the left bottom side.
    • Clean the immediate area of the filter housing, to make sure no dirt ends up in the engine.
  3. 2010-2017 Suzuki Swift Engine Air Filter Replacement, add new filter: step 3, image 1 of 1
    • With the square corner at the correct position, slide the new filter in.
    • Make sure the filter fits up with the backside of the air intake on all sides.
  4. 2010-2017 Suzuki Swift Engine Air Filter Replacement, close the filter housing: step 4, image 1 of 2 2010-2017 Suzuki Swift Engine Air Filter Replacement, close the filter housing: step 4, image 2 of 2
    • Underneath the air filter, 2 holes have to line up with plugs on the filter housing.
    • Once the underside is connected correctly, a small plastic protrustion has to line up with a corresponding guide on the air intake.
    • Clip back the 2 clips, and you are done.
Finish Line
knipwim
8,527 Reputation
30 Guides authored
One Comment
Thanks a lot
burakkurhan - Reply
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 135
All Time: 6,440
