2009-2015 Toyota Prius Grab Handle Replacement
  1. 2009-2015 Toyota Prius Grab Handle Replacement, Grab Handle: step 1, image 1 of 3 2009-2015 Toyota Prius Grab Handle Replacement, Grab Handle: step 1, image 2 of 3 2009-2015 Toyota Prius Grab Handle Replacement, Grab Handle: step 1, image 3 of 3
    • Locate and lift the handle above the driver's or passenger's seat.
  2. 2009-2015 Toyota Prius Grab Handle Replacement: step 2, image 1 of 3 2009-2015 Toyota Prius Grab Handle Replacement: step 2, image 2 of 3 2009-2015 Toyota Prius Grab Handle Replacement: step 2, image 3 of 3
    • Find tabs for removal of joint cover.
  3. 2009-2015 Toyota Prius Grab Handle Replacement: step 3, image 1 of 3 2009-2015 Toyota Prius Grab Handle Replacement: step 3, image 2 of 3 2009-2015 Toyota Prius Grab Handle Replacement: step 3, image 3 of 3
    • With a spudger, enter the tab and gently apply pressure to disconnect the joint cover from the assembly.
    • Slowly apply pressure away from the frame.
    • Notice that the joint cover is hooked on the inside. Be careful not to damage it.
  4. 2009-2015 Toyota Prius Grab Handle Replacement: step 4, image 1 of 2 2009-2015 Toyota Prius Grab Handle Replacement: step 4, image 2 of 2
    • Repeat the steps to remove the other joint cover.
  5. 2009-2015 Toyota Prius Grab Handle Replacement: step 5, image 1 of 2 2009-2015 Toyota Prius Grab Handle Replacement: step 5, image 2 of 2
    • Remove the handle leaving behind the metal clips.
  6. 2009-2015 Toyota Prius Grab Handle Replacement: step 6, image 1 of 3 2009-2015 Toyota Prius Grab Handle Replacement: step 6, image 2 of 3 2009-2015 Toyota Prius Grab Handle Replacement: step 6, image 3 of 3
    • With a pair of pliers or with your fingers, pinch and pull on the metal clips to remove them.
  7. 2009-2015 Toyota Prius Grab Handle Replacement: step 7, image 1 of 3 2009-2015 Toyota Prius Grab Handle Replacement: step 7, image 2 of 3 2009-2015 Toyota Prius Grab Handle Replacement: step 7, image 3 of 3
    • When replacing the handles, ensure that the metal clips are pointed inward toward the manifold.
    • Insert until it snaps in place.
  8. 2009-2015 Toyota Prius Grab Handle Replacement: step 8, image 1 of 3 2009-2015 Toyota Prius Grab Handle Replacement: step 8, image 2 of 3 2009-2015 Toyota Prius Grab Handle Replacement: step 8, image 3 of 3
    • Insert the joint covers diagonally ensuring the hook is not damaged.
  9. 2009-2015 Toyota Prius Grab Handle Replacement: step 9, image 1 of 2 2009-2015 Toyota Prius Grab Handle Replacement: step 9, image 2 of 2
    • Secure and test the handle.
Finish Line
Erick
169 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 34
All Time: 126
