2009-2015 Toyota Prius Engine Air Filter Replacement
Video Overview
  1. 2009-2015 Toyota Prius Engine Air Filter Replacement, Engine Air Filter: step 1, image 1 of 1
    • Locate the air box in the engine compartment
    • source.
  2. 2009-2015 Toyota Prius Engine Air Filter Replacement: step 2, image 1 of 1
    • Unclip the air box by releasing the clips holding it in place
    • source.
  3. 2009-2015 Toyota Prius Engine Air Filter Replacement: step 3, image 1 of 1
    • Carefully slide the air box out, making sure to avoid damaging the connected components
    • source.
  4. 2009-2015 Toyota Prius Engine Air Filter Replacement: step 4, image 1 of 1
    • Remove the old engine air filter from the air box
    • source.
  5. 2009-2015 Toyota Prius Engine Air Filter Replacement: step 5, image 1 of 1
    • Inspect the old filter and determine if it needs replacement based on its condition and mileage
    • source.
  6. 2009-2015 Toyota Prius Engine Air Filter Replacement: step 6, image 1 of 1
    • If the filter needs to be replaced, insert the new engine air filter (part number 17801-37021) into the air box
    • source.
  7. 2009-2015 Toyota Prius Engine Air Filter Replacement: step 7, image 1 of 1
    • Reinstall the air box by carefully sliding it back into position and securing it with the clips
    • source.
    • Remember to always check your engine air filter when replacing it, and be mindful of your driving environment, as some areas may be dirtier or dustier than others
    • Regularly replacing your engine air filter can help maintain optimal engine performance and efficiency.
eCuration
378,292 Reputation
236 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,524 Guides authored
One Comment
What is above the air filter? It looks like another filter that has been glued to the housing right above the replaceable filter.ty
will scott - Reply
Past 24 Hours: 0
Past 7 Days: 14
Past 30 Days: 80
All Time: 1,945
